BIKELAND > FORUMS > ZX-14.com > Thread: Nitrous solenoid in the airbox NEW TOPIC NEW POLL POST REPLY
kawasakijockey
posted January 22, 2010 08:10 AM
Have any of you guys put the solenoid inside the rear of the airbox when using a spraybar?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
Stu64
posted January 22, 2010 08:25 AM
Had mine in the battery box,both solonoids.
I see the Adams system is like that. I already have the spraybar, and I'm thinking of ordering the rest of that setup.
1badzx12r
no but i did have it in the battery box .. i also have an air compressor stuffed in there also ..
but when i replaced my battery i put a busa battery that was smaller in height in
kawasakijockey
posted January 22, 2010 08:34 AM
I am doing this on a customer's bike and was curious if it was done before and if there were any problems.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted January 22, 2010 11:54 AM
Just for thulought, would you want stuff like that in your air box? What if something vibrated loose (nut, washer) that could be pretty bad. I know nothing about those setup, that's just my first thought
kawasakijockey
posted January 22, 2010 02:36 PM
The only hardware that could be a remotely possible problem is the solenoid nut or if the nitrous jets fell out of the fittings. There is no other hardware in there.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
XLR8S
posted January 22, 2010 02:43 PM
The 12 I took in trade for my top gas bike has the solenoid in the air box with a bulk head fitting in the access cover. I know from experience with my top gas bike that solenoids can and do develop leaks. I'm not sure a nitrous leak in the airbox that can't be shut off would be a good thing.
ZX14, 1 piece at a time............. Roger
posted January 22, 2010 03:53 PM
i would never put that stuff in the air box. i have everything but the foggers and half of the lines from the d blocks on the outside( 8 tiny holes in the back of the air box sealed with silicon around the 1/8 ss lines)
87gtNOS
posted January 23, 2010 08:30 AM
How are you guys adding fuel? Sorry for the questions...I haven't paid much attention to the ZX14 nitrous....
I have TONS of nitrous experience.....about 14yrs worth, with my Mustang and snowmobile!
Can we fog the airbox and add fuel via the PC3? Have you guys heard of Holtzman nitrous? The nozzle is regulated, bottle temp is not an issue, ever!
Here's vid of testing the system (making sure fuel is feeding and the nitrous sprays at WOT)
http://www.youtube.com/watch?v=3KyQf6SpWt0
Those two nozzles feed a dyno proven extra 90hp! Motor was 165hp SAE....nitrous 245+ 160ftlbs!!
They each spray 15gram/second of nitrous....each worth 45hp! So one 10gr/sec nozzle for 30hp and the PC adding fuel could be a simple combination.
And believe me, they fog the shit out of that airbox!! I have little side vents added and there is so much nitorus that is sprays out the side vents if their not slid shut!!
01 ZX12R
0.23983216285706 seconds processing time
