BIKELAND > FORUMS > ZX-14.com > Thread: Question on turbo fuel pressure NEW TOPIC NEW POLL POST REPLY
Bad in Black
posted October 31, 2009 05:01 AM
I haven't got to start my turbo 14 up yet, but I did hook the fuel system up and primed it by turning the key on and off. Everything held fine, and the pump did its 3 second cycling. I did that several times, but my fuel pressure gauge never showed any fuel pressure. Maybe I have to do it some more to fill the empty lines? Or will I need the bike running to actually see fuel pressure numbers on the gauge?
zxbob
posted October 31, 2009 08:31 AM
The fuel pump should cycle when you turn on the key (not started)
You can try to start it, it may just be the gauge.
Bob
bigwil
06 zx 14 turbo stage 3
posted October 31, 2009 10:48 AM
if you prime it with the key a few times you should have pressure
tunn the key on and crack open the line at the gauge if there is no pressure check
if the neg/ground is not backwerds
bigwil// going fast aint easy so turbo it
0.2233190536499 seconds processing time
