BIKELAND > FORUMS > ZX-14.com > Thread: Changing from 17t to 16t, which speed correction device? NEW TOPIC NEW POLL POST REPLY
BenzTech
Dirty Jersey
posted October 27, 2009 04:11 PM
After plenty of researching gear ratios etc. I've decided to go with a 16t sprocket and leave the stock rear 41 to start. I understand the bike stock has a +8% speedo error and adding a 16t will make it worse. My question is which is the best "speedo correction" device. Ive seen the speedohealer and a product from Muzzy called the Bonneville pro. Are there more? and which is the most popular with you guys. Thanks.
07 ZX14 SE with chicken strips
Wheelie
Old Man
grinder
wee
BenzTech
Dirty Jersey
posted October 27, 2009 04:16 PM
I saw the whole grind off a corner thread, but wont that drop the reading by 25%? Im looking for a little more accuracy (I think)
ninjaboy311
Dremel
INTIMIDA2OR
RED rider!
posted October 27, 2009 05:08 PM
Well which ever method you go with ,know that your odometer will be off even though the speed will be accurate.
'06 Passion Red ZX-14
*Lee*
Wheelie
Old Man
posted October 27, 2009 05:10 PM
what controls the od?
wee
posted October 27, 2009 05:23 PM
I thought the odometer was controlled the same as the speedometer?
Wheelie
Old Man
posted October 27, 2009 05:38 PM
got 2 corners rounded off and my speedo/od seem right with my 16/48 gearing
wee
BenzTech
Dirty Jersey
posted October 27, 2009 05:39 PM
I believe both odometer and speedo use same signal. Less registered MPH=less mileage im thinking, chime in if im wrong.
BenzTech
Dirty Jersey
posted October 27, 2009 05:43 PM        Edited By: BenzTech on 28 Oct 2009 01:44
Another question about grinding a corner, does this effect the needle at all..like cause a bouncing speedo needle at all at any speed?
sj1400
posted October 27, 2009 06:00 PM
Anyone try out the Bonneville pro yet ?? My speedohealer works fine but the factory gear indicator is off at anything more then 7%.. Will the Muzzy box disrupt the factory gear indicator ?
Wheelie
Old Man
posted October 27, 2009 06:06 PM
no
wee
masszx14
A mind beside itself!
posted October 27, 2009 06:38 PM
You want the Speedohealer V4.
Don't worry about the odometer- there's 8% speedo error but the odometer is precise and the healer will not interefere with that.
universal@mind
Bawls
re-learning to ride
posted October 27, 2009 08:03 PM
Hey wheelie, shoot me an e-mail at chadley.yates@gmail.com I would appreciate a little more info on the cs nut grinding since I'm going to be running 16/46 gearing in a couple of days.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
Bad in Black
posted October 29, 2009 12:12 AM
I agree....the V4 rocks. Its super easy to set up, and with the push of a button goes from restricted to unrestricted speedo. Plus it has one-touch high speed recall. I mounted mine under the gauge console, and couldn't be happier with it.
posted October 29, 2009 05:06 AM
bawls, if your worried about hitting the rev limiter, you will be fine. just done it w 16/48
FlatoutBu
posted October 29, 2009 05:08 AM
Me too...+1 works great
06 Blue 14
9.008 at 153mph @ 195 suited
Hurricane
posted October 29, 2009 02:05 PM
SpeedoHealer V-4 +1
Wheelie
Old Man
posted October 29, 2009 02:42 PM
email sent
wee
Bawls
re-learning to ride
posted October 29, 2009 03:17 PM
got it... thanks! I'm just trying to get my speedo a little closer to being correct since i still ride my bike on the street. Going in a little bit to put the rest of my parts on. I'll try to get some pictures when i'm done.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
INTIMIDA2OR
RED rider!
posted October 29, 2009 03:48 PM
Correct , Both the speedo and the odo use the same signal. Any change in the signal changes the reading. The ODO is really accurate stock but the speedo is off.
Fix the speedo and the ODO will be off a little bit. Probably not off enough to worry about. But I love my ODO and trip counters more than I like my speedo
I believe it messes with the gear indicator a bit too , cause since I've been running the 190/55 tire I've noticed the gear indicator be a bit lazy .Like at a light it will read that I'm in 1st gear
but when I take off I'm in 2nd. And when shifting up it will read one gear lower than I am actually in for a few seconds.
Didn't do it with the 190/50 .
*Lee*
posted October 29, 2009 03:56 PM
i dont think that has to do with your tire, bc with all the extra gear i run (16/48) it dosent do that.
INTIMIDA2OR
RED rider!
posted October 29, 2009 04:28 PM
Hmm . I wonder what else could cause that? Strange stuff . Now it's got me thinking . Thanks a lot man just when I had a good reason for why the gear indicator is doing what it's doing you gotta come along and spoil it lol !
*Lee*
posted October 29, 2009 05:17 PM
I hear ya! My 06 did that sometime. I think it did it more when the bike didn't go all the way in gear. It did it at random, I think it had a mind of its own.
makenna
posted October 29, 2009 09:21 PM
I am thinking about going to a 16 tooth in the front. I have a 43 in the rear and speedohealer already. Do you figure dropping down a tooth in the front to a 16 will make that much of a difference in rideability?
English is the only language that matters.
0.30257201194763 seconds processing time
