BIKELAND > FORUMS > ZX-14.com > Thread: muzzy slip ons NEW TOPIC NEW POLL POST REPLY
zx14fan
posted October 26, 2009 09:40 PM
muzzy slip ons
New to the site.I would like to ask an opinion about the muzzy carbon slip ons.I have a box stock 09 and i would like to order the muzzy slip ons and a KnN air filter.I have heard that its possible to lose a little bottom end has anyone experienced this with muzzy slip ons? If that is the case would a pc help correct the problem.I ride alot in the twistys and dont want to lose any botton end if i can help it. I would like to here your opinion if anyone with an 08 09 has this setup.to my knowledge muzzys are quiet compared to most slip ons is this the case? I dont want loud.Thanks for the advice.
INTIMIDA2OR
RED rider!
posted October 26, 2009 11:54 PM
You will like the Muzzy carbon slipons . They are not too loud but have a deep mellow tone. I would pull the secondary flies and use a BMC filter rather than the K&N.You shouldn't lose any bottom end.
'06 Passion Red ZX-14
*Lee*
posted October 27, 2009 03:55 AM
pulling the flies will make a lot of difference!
LAB3
posted October 27, 2009 06:21 AM        Edited By: LAB3 on 27 Oct 2009 14:22
I had Muzzy slip on's, fly's out, K&N and a PC with the map for all. Added low end power
over stock mufflers. And sounded Great, mellow tone and Not Loud.
First post.....Welcome to the site.
Flame On
Fuel Air & Spark
posted October 27, 2009 06:29 AM
You will lose wieght and better handle & power feel over stock a PC would impove it more but I know so ride the 14 without the pc and slip ons.
77 RD 400
80 GS1000 GT
06 ZX14
zx14fan
posted October 27, 2009 07:30 AM
Thanks guys for the info.Some say that the 08 09 flys out dosent do a alot for the bottom end but many here on the site think its the way to go?Would you say that with the flys out and a pc that the throttle would be as smooth as stock through the power band without flat spots? And also what about pinging at lower rpms with the added bottom end power? Thanks for the input.
BenzTech
Dirty Jersey
posted October 27, 2009 07:41 AM
I also have Muzzy Slip-ons
I have the oval stainless version. My bike is a 07 SE. They sound great and have not noticed any bottom end power loss. Flies in, no pc. stock air filter.
07 ZX14 SE with chicken strips
oldkawboy
posted October 27, 2009 09:04 AM
I had a '07 14 with Muzzy's carbon slip-ons and they worked great. The sound was perfect to me plus I still like the balance look of two mufflers. If you want a tad more power & better sound, you'll love the slip-ons........top notch quality too.
A flies out bike with PC can be just as smooth (rideable) as the stocker. I could tell the difference on pulling the flies from my '08.
For all out performance though, a single sided full system is the way to go.
Dan
INTIMIDA2OR
RED rider!
posted October 27, 2009 09:59 AM
Pulling the flies makes a difference you can feel!
*Lee*
zx14fan
posted October 27, 2009 10:49 AM
Thanks dan that answered my question.What pc for this set up works the best for the street? Muzzy- brocks or ? Also does it change the cold high idle speed?
oldkawboy
posted October 27, 2009 02:35 PM
I went to Muzzys web-page and downloaded a map for their slip-ons when I had my '07. I believe the number was #009 but I'm not sure about the '08 & '09
It doesn't matter where you get the PC from, just shop around from a reliable source.
I can't remember ever having an issue with the idle but it's been a while......sorry.
Dan
Chief
KR Tuned Exhaust
posted October 27, 2009 03:46 PM
I have slip-ons and stock air filter. If I pull the fies on the 08 will I have to add a pc. Thanks.
zx14fan
posted October 27, 2009 04:03 PM
Thanks again.Ok one more Q,would a pc help with muzzys and the flys in?
oldkawboy
posted October 28, 2009 06:48 PM        Edited By: oldkawboy on 29 Oct 2009 02:51
The '08's & '09's are pig rich up top from the factory and usually leaning the bikes out with a PC will help performance but my youngest son recently bought an '08 14 and left the flies in and just installed a Brock's full system and his runs GREAT.
I'm thinking that if you add slip-ons and an aftermarket air filter it may lean the bike out enough where no PC is needed as long as you leave the flies in.
But.............if you're wanting all-out performance a PC is needed to fine tune the mapping.
Good luck with your decision.
Chief,
I'm not sure what to suggest on the '08's as far as having to install a PC when removing the flies. I know on my oldest sons '07 the bike went dangerously lean, like 18:1 when he removed the flies.
I know the '08 & '09's are richer, I just don't what is safe on those models. Surely some one with experience will chime in.
Dan
kaw now
posted October 28, 2009 08:56 PM
I ride the twisties a lot also so I can appreciate all around power. First of all the 14 does not get out of breath at any rpm. The only reason for slip ons over a full header system is only ease of install or looks if you prefer. I installed a Yosh R77 and it has more power all over compared to stock. That can be backed up by dyno charts especially north of 7k rpms. I use a stock filter with the screen cut out just some flush cuts to the plastic rivets and its gone. The power is smooth and usable all over. Mine is an 06 with flies removed as it was necessary on the 06-07s. I also have the PC. If I had the 09 i would leave the flies in and install a full system. Don't know about the PC and tune for that.
zx14fan
posted October 28, 2009 10:25 PM
The full systems are nice and they do make more power then the slip ons but what i dont like is that most are four into one and they are all too loud.Some day we ride hundreds of miles that kind of sound can drive you crazy on the long rides.If you get the full system you need the pc that much i do know.
kaw now
posted October 29, 2009 01:14 PM
Quiet yup thats why I got the Yosh with the silencer installed its really quiet and more torque down low to mid with it installed. Ask around its one of the quietest and lighter than slip ons.
Bawls
re-learning to ride
posted October 29, 2009 01:26 PM
the full muzzys or brocks gen3 are pretty quiet. i think that you might be surprised if you ever ride with one.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
gilberjj
Friend of Fast
posted October 29, 2009 07:57 PM
They are nice, but I liked the ti-force/orient express exhaust the best. Great looking, superior build quality, and lower price. I don't like slip-ons because they cost just as much as a full system (in many cases), and they make less power.
zx14fan
posted October 30, 2009 08:57 AM
The four into one full systems are not always the best for low end to mid range power for the twistys.
LAB3
posted October 30, 2009 09:19 AM
That depends on who's 4/2/1 system and does it have a good map for where you are riding..higher in mountains. Oh and what rear gear?? That was a plus in the Ozarks.
kaw now
posted October 30, 2009 11:31 AM
Four into ones not always not as good in the twisties a myth really. My bike is more responsive at all rpms and not peaky either as the basic engine characteristics have not changed. I use mine all the time that way just not true thats its not as good. And thats right at sea level cool days or whatever the bike is better because of the lower weight.
0.2273108959198 seconds processing time
