BIKELAND > FORUMS > ZX-14.com > Thread: changed front cog /clutch not engaging NEW TOPIC NEW POLL POST REPLY
Douglas Home
posted October 22, 2009 09:32 PM
Hi guys , I'm not very good mechanicaly but tackle the easy jobs.
I just changed my front spocket over and now when it is on a rear stand with the clutch in and in gear the back wheel still turns .
should I just undo the three bolts on the clutch cylinder and pull that out then put back in?
I am sure I didnt touch the clutch lever when it was apart.
I did this job once befofe and it all went smooth.
Help ,as I'm racing tommorow morning!!!
I'm standard wheelbase and changing back to standard 17 tooth as I'm having trouble launching. thanks
Doug Mackay Australia
INTIMIDA2OR
RED rider!
posted October 22, 2009 10:16 PM
Does the clutch lever have good pressure? Did you try putting it in gear while the bike is on the ground?
Sometimes the oil gets between the plates and makes the wheel turn even thoulg the clutch is engaged.
'06 Passion Red ZX-14
*Lee*
Douglas Home
posted October 22, 2009 10:24 PM
I took the whole cover back off , replaced it ,still the same.
Its on a rear stand but full pressure with my foot doesnt stop the wheel turning.
The clutch lever does feel a little soft.
Bloody stressin!!
Douglas Home
posted October 22, 2009 10:29 PM
I took the clutch fluid resevoir lid off to check the fluid and the rubber nob was down
not up , but had pleanty of fluid.
Douglas Home
posted October 22, 2009 10:46 PM
Read the manual and it looks like I undid the bleed valve.
I know my memory is stuffed and should have started back at the manual
INTIMIDA2OR
RED rider!
posted October 22, 2009 10:48 PM
I think the system sucked some air somehow .Try bleeding the clutch a bit and see if the pressure comes back.
*Lee*
INTIMIDA2OR
RED rider!
posted October 22, 2009 10:50 PM
If that don't work try applying the rear brake and see if it unsticks the clutch.
*Lee*
Douglas Home
posted October 24, 2009 03:20 PM
Bled the clutch ,and all was well.
Raced yesterday with the different cog ,my spray packed up , my shift light stopped working
but with luck not skill I won mod bike!!! (street bike)
I had never won anythink in my life and to cap it off it was our biggest meeting of the year.
Without a doubt the best high I've ever experienced.
Life is awsome!!!
INTIMIDA2OR
RED rider!
posted October 24, 2009 03:43 PM
Awesome !
*Lee*
LAB3
posted October 24, 2009 04:09 PM
Way to go Doug :-)
Louis
posted October 24, 2009 09:18 PM
Congrats...
posted October 25, 2009 05:12 AM
congrats!
posted October 25, 2009 05:40 AM
Great job!!
Douglas Home
posted October 25, 2009 09:31 PM
Thanks guys ,Hopefully I will get lucky again?
Dont know if you have heard of Steven Bradbury, but he is an Ozi ledgend!
He got an ice skating gold medal when EVERYBODY in the race fell 20 meters from the finishline and he went from last to gold medal!!!!
It was Australias first winter olympics medal and he is as popular as Ned Kelly.
He lives on junk food and loves nothing better than living in his car on extended surf trips.
0.29826784133911 seconds processing time
