BIKELAND > FORUMS > ZX-14.com > Thread: Carpenter 210HP...Still Streetable? NEW TOPIC NEW POLL POST REPLY
BIG BLUE_ZX14
posted October 10, 2009 04:59 PM
http://www.carpenterracing.com/zx14.htm
These packages look sweet and I might be able to swing one later in the winter. Clearly the later packages would not be very streetable but what about the first two? The 210+HP package doesn't look too much for the street and even the 215HP. Anyone have this done or know how streetable these packages are? I'll take opinions on if these mods are over the top for a street bike...Thanks.
2007 Blue ZX14 Gone...
posted October 10, 2009 05:13 PM        Edited By: Shane661 on 11 Oct 2009 01:14
The first thing I would consider is the correction factor, and what the engine is going to make on pump fuel. For example, a 210 STD hp engine running on race fuel is going to be less than 200 hp SAE on pump.
All that being said, the 210 engine looks mild...with the 215 package having bigger cams. Depending on the size of those cams, it might not be an ideal street engine.
First and foremost decide how you want to use the bike...that will determine which set of compromises you wish to choose, engine-wise.
posted October 10, 2009 05:18 PM
Maybe a thought, isn't a small turbo kit not much more than that? Imho a turbo would be a lot of fun!
BIG BLUE_ZX14
posted October 10, 2009 05:31 PM
I didn't even think about the different fuels. I guess the HP numbers they are quoting would be for race fuel, I can ask them about that.
Well, street racing (kind of) is my primary use. Everyone can lecture me later but around here we find empty stretches of HWY and open it up. Roll-ons from any gear and who ever hits the next exit first is the winner. That being said if its not raining (too hard) im riding everywhere and everyday so I need streetable.
06redzx14
posted October 10, 2009 08:19 PM
just a head and cams use the small cams and you'll be fine
kawasakijockey
posted October 10, 2009 11:18 PM
Nitrous is still cheaper for a while.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
SticknMove
posted October 12, 2009 11:09 AM
I don't need Carpenters, and I have 205 hp with the right map, vp fuel, bm air filter. Stock motor.
Da New King
Douglas Home
posted October 12, 2009 11:12 AM
I might put my bike on that dyno???
Doug Mackay Australia
posted October 12, 2009 11:28 AM
Forget the right map...for 205 stock motor hp it's more about the "right dyno"!!
Bently
2012 14r In Blue and no Mods!
posted October 12, 2009 11:38 AM
Ya there was a dyno shootout here saturday and my buddy took his 08 busa to it and made 202 on 93 pump gas and 248 on a 40 dry shot with a mps spider kit. I did not go but know for a fact my 14 always dynos around 6 to 8 hp less then his busa but runs the same at the track. so if your 14 is showing 205 man that's a happy dyno. just for reference my buddy had his 08 on this dyno and made 200 hp then drove 45 miles to another dyno and made 189 same day same gas. so what dyno to you think is more accurate i know which one i will go with. but hey all harley shops dynos read high how else can you feel good about spending 2500 to 4000 on a big bore kit and not make 90 hp still.
posted October 12, 2009 11:48 AM
I must own the weakest zx14 made ... Mine dyno's at 177 hp ..
Sticks_n_Stones
posted October 12, 2009 12:00 PM
Guess I have the second lowest: 176rwhp
And the half dozen zx14's that dyno'd lower than me? Well, they must have had fouled plugs or something... 200+rwhp stock engine my ass.....
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
Sticks_n_Stones
posted October 12, 2009 12:07 PM
what other packages are out there? If I had $3500 to spend, where would you guys recommend I go???
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
06redzx14
posted October 12, 2009 12:11 PM
I know where you can get a nice used turbo for that
Bently
posted October 12, 2009 12:20 PM
No you just got the weakest dyno LOL.
Sticks_n_Stones
posted October 12, 2009 12:38 PM
No turbo's, I plan on doing track time with the bike. no, the "other" track time.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
SteddyTeddy
posted October 12, 2009 12:53 PM
They must of had the CPU for that dyno in a super cold,pressurized and dehumidified room! LOL
Hurricane
posted October 12, 2009 01:01 PM
Maybe that 205 is in the metric system!!!
Bently
posted October 12, 2009 01:24 PM
Steddy if your talking about my buddys run it actually was only 34 degrees outside saturday but still they have it set to read high
posted October 12, 2009 01:31 PM
i got all you guys beat! 160hp here...
01smokes
posted October 12, 2009 01:50 PM
damn i always thought i was the lowest with 163HP and a corrected HP of 131 lol
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
SteddyTeddy
posted October 12, 2009 06:03 PM
34 degrees, and he we are still sweating down here. At that temp the correction factor should have taken power away from the uncorrected #.
Pretty Fast
posted October 12, 2009 06:07 PM        Edited By: Pretty Fast on 13 Oct 2009 02:15
I'm making right at 210 at the rear and thats with the 1417 2 mil overbore on pump. U will never attain that on any stock 14 or any stock street bike for that matter, that I know of. Yes it is very streetable. No heating problems at all. They do make a 3 mil 1445 or 1450 but the walls are getting a bit thin at that point. Not a lot of room to bore out on the 14's like u can with the busa. This package below that Carpenter is offering that claimes 210+ with just head and cams and no pistons or increased stroke is a bit exaggerated IMO. His HP claimes is 10 to 15 HP higher than what you will actually get on pump gas.
CARPENTER:
210+ includes CNC Head Porting/ Custom Camshafts/ High rate Valve Springs/ Retainers/Auto Cam Chain Adjuster, and Clutch Mod. $3700
INTIMIDA2OR
RED rider!
posted October 12, 2009 09:10 PM
Geez you guys got me beat! I got only 157 on Kerry Bryants dyno! I think he purposely gave me low #'s lol
'06 Passion Red ZX-14
*Lee*
Bently
posted October 13, 2009 04:39 AM
Teddy I would rather be sweating, this weather sucks and it's just starting!
0.26675891876221 seconds processing time
