BIKELAND > FORUMS > ZX-14.com > Thread: zx 14 front sprocket? NEW TOPIC NEW POLL POST REPLY
elmostro
posted October 09, 2009 04:21 PM
Thello everyone, this is my first post. i have a problem. trying to change the front sprocket i used a 12 point socket and striped the front sprocket nut using a 12 point 1 1/16 socket. what are my options to get that nut off. i notice the nut have two sockets size one is 1 1/16 and the other one is a lot bigger. what can i do fix the bike? thanks for looking
14nooby
posted October 09, 2009 08:02 PM
There are actually 3 different heads on that nut. I used a 6 point 35mm and it worked on the very back size. There is not much to grab but it should work. I am going off of memory so hope its right. Nice Avatar BTW
posted October 10, 2009 09:06 AM
I can check when I get home, but I thought it was a 27 or 37mm.. Thinking the 27. I will be home in a few hours and will post it. DONT USE A 12 POINT!!! Search the part stores until you find the 7 or 8 point, whichever it is.
posted October 10, 2009 09:48 AM
27mm on mine.
elmostro
posted October 10, 2009 04:23 PM
thanks the 27 fits pretty good, i tried a 35 for the outer area an is a bit too big, too much play i think a 34 might fit better but i don't have one.
makenna
posted October 10, 2009 05:50 PM
I just changed mine he other day and it was a 27mm deep, six point socket. Put the pneumatic gun on it and it came off no problem; of course I remembered to turn the washer back down to flat first too...
Good luck with the stripped nut, I hope it works out for you.
English is the only language that matters.
elmostro
posted October 10, 2009 06:05 PM
the washer is flatened, my problem is the 27mm is half way striped, i guess i need to get the bolt out using the 34 or the 35mm socket. the nut come off like every nut turning left rigt?
posted October 10, 2009 06:11 PM
yes it is standard thread.. its a pain to get off if you havent noticed already. i got a 5ft cheater bar, and i stuck a 2x4 in my back rim to stop it fron turning bc someone stnading on the brake wouldnt hold it from turning. good luck!
makenna
posted October 10, 2009 06:12 PM
Come off like every other nut. You should think about replacing that nut once you get it off.
bruno nadeau
posted October 10, 2009 06:13 PM
yes
bruno nadeau
elmostro
posted October 11, 2009 04:33 AM
I'm using my IR impact wrench 600ft-lbs and still can't get this monster off. will keep you inform of the outcome. thank you all for help
posted October 11, 2009 04:54 AM
Get a 5ft cheater bar, but a board in the rear rim, and get someone to sit on the bike.
elmostro
posted October 11, 2009 05:09 AM
i tried didn't work. the thing is on permanent lol
posted October 11, 2009 05:20 AM
How did it not work?? Were you picking the bike up?
elmostro
posted October 11, 2009 05:32 AM
nope, i'm been working with bikes for a while, this one is some else. who ever put this bike together is an A** Ho** . he didn't follow procedures. i mainly work with busas. i used all my little tricks that i know on this one and none of them work. maybe i need a drink or two.
posted October 11, 2009 06:02 AM
They are a pain to get off. My 06 was the same way. The 08 did fine, with the cheater bar.
bruno nadeau
posted October 11, 2009 07:04 AM
i use an impact to,lock the rear brake it take me about 10 minutes non stop with the impact before it come loose.
bruno nadeau
elmostro
posted October 12, 2009 02:06 PM
got it out, the nightmare is over. i used a 27mm deep impact socket and my baby IR impact gun and the nut just felt off. i cuoldn't belive it. thanks guys
posted October 12, 2009 02:30 PM
Glad to hear u got it off!
posted October 12, 2009 04:49 PM
heat does wonders with loctite too, I have had to heat the nut with a torch on a friends, carefully as not to heat the shaft and seal but get the nut hot so it expands and opens op a little on the shaft. the rubber damper was pretty ugly, and it was getting a new sproket anyway.
PS, I haven't put new loctite on my counter nut, and as long as the washer is in good shape, with a fresh corner bent up on the nut, Loctite is not required
elmostro
posted October 12, 2009 05:26 PM
thanks again, I told the owner of the bike which is my brother to get a new nut and a new washer. hopefully when we put everything back together he can keep up with my busa :-)
zixxer14
Damn that was Quick
posted October 12, 2009 07:25 PM
Put a 16 on & see who's rying to keep up!
BobC
posted October 13, 2009 12:19 AM
The best socket to use on the countershaft sprocket nut is the hexagonal variety which bears on the flats of the nut, not the corners and should not round it off.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
0.24409890174866 seconds processing time
