BIKELAND > FORUMS > ZX-14.com > Thread: 190/50 vs. 190/55 NEW TOPIC NEW POLL POST REPLY
joemugg
posted October 08, 2009 12:20 PM
190/50 vs. 190/55
I've heard a lot of riders install a 55 series rear to increase the turn-in character of their bike. What about lowering the front instead? A 55 rear is 9.5mm taller than a 50 rear (190/50=95 190/55=104.5) so would lowering the front 9.5mm yield the same result?
'97 GSXR600 street sweeper
posted October 08, 2009 01:08 PM
No. Lowering the front end will decrease your turning radius.
masszx14
A mind beside itself!
posted October 08, 2009 01:22 PM
Increasing height improves lean angle (well- gives you more of).
Same with tires profile and suspensions settings.
I would never use anything else but a 190/55 rear on my 14.
universal@mind
joemugg
posted October 08, 2009 02:31 PM
Oh yeah, good point. I was thinking of rake without considering ride height.
derpie
Dont judge a book by its cover
posted October 08, 2009 04:19 PM
Isn't the 55 narrower than the 50 ?
joemugg
posted October 08, 2009 04:34 PM
No, the first number is the width, the second number is the sidewall height represented as a percentage of tread width, 50% or 55% of 190mm. So they're both the same width, different heights.
posted October 08, 2009 04:46 PM
Dosent it come w a 50?
masszx14
posted October 08, 2009 07:04 PM
It comes in the wrong size and the wrong brand/ model IMHO
You don't ride twisties, you would have noticed a big improvement
with the 190/55 if you did.
universal@mind
INTIMIDA2OR
RED rider!
posted October 09, 2009 12:53 AM
I agree! I run the 190/55 and I used to drag the lower fairings with the 50 profile and and I dragged the lowers with the with the 180/55 . Haven't been able to drag the lowers with the 190/55. Seems to be the perfect tire for twisties on this bike
'06 Passion Red ZX-14
*Lee*
posted October 09, 2009 03:41 AM
i dont do twisties, so ill stay where im at.
14nooby
posted October 09, 2009 03:49 AM
If you drag race the 190/55 is no good. I just ran into that problem because it rubbed my inner fender really bad.
posted October 09, 2009 04:12 AM
i actually am getting a 180/55. i hope it dont rub..
joemugg
posted October 09, 2009 06:38 AM
Anyone know the equivalent gear change when switching to a 190/55 rear? It would be like going to a smaller rear sprocket, but how much smaller?
masszx14
posted October 09, 2009 06:39 AM
180x0.55=99
190x0.50=95
190x0.55=104.5
universal@mind
14nooby
It shouldn't run Dusty. I went to Cycle Gear yesterday and compared the 190/50 Shinko to the 180/55 Michelin and they are really close in height. I'm going to the track tonight for the first time with my 180 also. Hope it doesn't rub to.
posted October 09, 2009 06:43 AM        Edited By: Shane661 on 9 Oct 2009 14:47
By switching to a taller rear tire, you are changing the effective rake and trail. In this case, it will steer more agressively, at the cost of some stability. I wouldn't alter the steering geometry like this without installing a damper.
In order to know the actual affect on gearing you would have to measure the two tires when installed on the rim. In this case, you will most likely be looking at the equvalent of a tooth or more.
In regards to a shorter front tire, it will also make the bike steer more quickly, for the above mentioned reasons. I am not great with math, so I can't tell you what change in the front equals what change in the rear, I'm afraid. But it is possible to calculate this with some geometry skills.
posted October 09, 2009 07:42 AM
I failed geomotry in 10th grade. I'm useless in that category
gilberjj
Friend of Fast
posted October 09, 2009 07:55 AM
I put on a 55 rear and it was glorious in the corners. If you ride twisties a lot, I would highly recommend it.
joemugg
posted October 09, 2009 10:43 AM
Adam at Vortex says its similar to one tooth down on the rear, approximately 2%. Shane, what gearing and tire size do you run for LSR? What's your top speed so far?
posted October 09, 2009 11:32 AM
I run a 190/50 tire. As far as gearing, it depends on the distance of the venue and what I feel the peak speed will be. I have run everything from 16/41 to 17/38. My top speed is 211.97 mph, which was obtained with 1.5 miles of track and a tailwind.
joemugg
posted October 09, 2009 01:52 PM
Damn! That's fast. How far from stock is the motor?
posted October 09, 2009 02:01 PM        Edited By: Shane661 on 9 Oct 2009 22:02
Stock motor, with bolt-on mods and MR9 fuel.
Fastest-14
Fastest -14
posted October 09, 2009 02:14 PM
Shane wasn't u the one who put the 4 mil crank with the stock bore in?
What was most effective in getting u past the 186 limiter?
Which gear ratio was u running when u ran 211 mph?
posted October 09, 2009 02:17 PM
No, my motor is stock with about 2500 miles on it. I have a speedohealier, but I will be removing it when convenient and grinding the countershaft nut, most likely. I had 17/38 on the bike...but it could have done it (and maybe a little more) with 17/39. I had to borrow the sprocket at the track.
joemugg
posted October 09, 2009 06:53 PM
I'm curious, Shane, why dump the SH in favor of grinding the nut?
0.33829212188721 seconds processing time
