BIKELAND > FORUMS > ZX-14.com > Thread: "Engine flush" NEW TOPIC NEW POLL POST REPLY
Learning2race
posted September 05, 2009 04:22 PM
"Engine flush"
Starting to think about getting the bike ready for storage. Ran across a couple product designed for automobile engines - both called "engine flush" - one made by Motomaster the other Penzoil. Concept is to add to oil, start and idle a 5-10 minutes, then drain/change oil.
Products claim to:
"Remove gum, varnish and sludge from internal engine parts and oil passages to help increase engine life. Also helps loosen piston rings, valves and lifters to restore optimum engine performance"
Wondering is anyone has used anything similar for bike application? Seems like a valid concept.
I have some concerns as to how this may affect the clutch fibers?
Thoughts/comments?
Learning2race
posted September 05, 2009 04:23 PM
Further - since I haven't found anything motorcycle specific, any concerns with running an automotive injector cleaner through the bike?
posted September 05, 2009 04:24 PM        Edited By: Shane661 on 6 Sep 2009 00:25
I would not use it.
Obviously it's probably not designed for wet clutch systems...but more than that...how much gum, varnish, and sludge do you think could be in there?
Regarding the injector cleaner, it should not be a problem. I have run some fuel system cleaner through the bike since I use MR9. It may or may not help, but should not hurt.
INTIMIDA2OR
RED rider!
posted September 05, 2009 05:03 PM
If you are planning to store the bike then I would use an oil stabilizer such as "lucas" to keep every thing coated . I once had an engine I ran lucas in that I tore down after it was sitting for 2 years and there was still Lucas stuck to all the cam lobes and the inside of the valve cover
Great stuff! Also car injector cleaner should work fine...
'06 Passion Red ZX-14
*Lee*
Flame On
Fuel Air & Spark
posted September 05, 2009 05:19 PM        Edited By: Flame On on 6 Sep 2009 01:20
Id piss in my motor rather than have to use Penzoil
77 RD 400
80 GS1000 GT
06 ZX14
Killjoy_1
posted September 05, 2009 05:55 PM
Just used the engine flush made by Motul. Stuff looked like off-road diesel and smelled like any other petroleum distillate. Oil came out darker. Have 20K on my 14.
AcadianaZX
Advertiser
posted September 06, 2009 12:34 AM
If there's a motorcycle specific engine flush out there for wet clutch bikes, I don't know. Fuel stabilizer and an oil & filter change is the norm with good results.
LAB3
posted September 06, 2009 04:13 AM
I change my oil and filter every 3000 miles was Mobil 1 Racing 4T. Have a case of
Amsoil 10W40 motorcycle oil I just got waitiing on another 3000 miles. Redline makes
good Fuel injector cleaner, never used it on the 14. Not much snow in Texas ride it
in the cold some too. Keep the gas tank FULL in winter.no rust. Tressie was cool
I got a shirt and she signed me up on the site :-) Thanks AccadianaZX.
AcadianaZX
Advertiser
posted September 06, 2009 04:24 AM
Thank you LAB3. That's why I snagged her up and married her.
James
Old Guy
posted September 06, 2009 08:18 AM
Sea Foam works well as a fuel stabilizer. Used it for years in outboards that sat for 9 months in AK.
Used it in my 14 while in Ak. this summer. No problem.
Living the good life...,
On a XZ !!!!!
Tsukigi stainless full system
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
Flame On
Fuel Air & Spark
posted September 06, 2009 08:41 AM
Lucas has a trust worthy reputation on there products I use the stabilizer jet cleaner every so often
77 RD 400
80 GS1000 GT
06 ZX14
INTIMIDA2OR
RED rider!
posted September 06, 2009 09:59 AM
Me too I'm guilty of using lucas products
*Lee*
Flame On
Fuel Air & Spark
posted September 06, 2009 10:59 AM
Good stuff race proven name
77 RD 400
80 GS1000 GT
06 ZX14
dcjens
Wet side of Washington
posted September 06, 2009 03:09 PM
I wouldn't use engine flush on a bike personally. It's diesel. I had a car motor I used that in and it cleaned it alright BUT flushed all the crap through the filter and back into the motor. I didn't drive the car but let it warm up and dumped it. I filled it back up with regular oil. The motor seized up within a month.
Black 06
Flame On
Fuel Air & Spark
posted September 07, 2009 01:20 AM
Seems like it would be better to add stabilizer to the last of the gas and then let it run till empty
Motomaster never heard of it
Penzoil dont even go there
77 RD 400
80 GS1000 GT
06 ZX14
AcadianaZX
Advertiser
posted September 07, 2009 01:47 AM
Keep a full tank for storage with stabilizer. Run for a short time to get it in through to the injectors before storage. Not sure about moto/penz products.
knydecker
Uber-BigPimpin
posted September 07, 2009 04:36 AM
If you live in an area where there is alot of moisture, I would coat any external metal parts with a light coat of wd-40. Full tanks of fuel w/ stab. Keep the tires off the ground. Disconntect the neg terminal on the battery unless doing a battery tender. Add some Decon around the bike as small animals are looking to nest in the winter (depending where you live). Cancel your insurance for that winter. I dont believe in adding somthing in the oil to hibernate the engine. Just drain and fill in the spring.
This was dictated... but not read!
BIKELAND > FORUMS > ZX-14.com > Thread: \"Engine flush\" NEW TOPIC NEW POLL POST REPLY
0.24786901473999 seconds processing time
