BIKELAND > FORUMS > ZX-14.com > Thread: pcv NEW TOPIC NEW POLL POST REPLY
zerotahero
posted August 09, 2009 09:50 AM
pcv
can someone tell mehow important is it to set throttle position on the pcv ?
will i get more power with it being set? guy that put it in loaded a map but did
not set throttle position. thanks
bruno nadeau
posted August 09, 2009 12:35 PM
it is important,let say you need more or less fuel at 2%and 3000 rpm if the TP is not set you can get it at 0% or 5%. at 3000.
bruno nadeau
AcadianaZX
Advertiser
posted August 09, 2009 07:23 PM
Throttle position is important. Do you have the instructions. I make sure it reaches 100% before I go to the track. If you don't have the instruction,I can email the to you.
James
0.35387206077576 seconds processing time
