BIKELAND > FORUMS > ZX-14.com > Thread: battery problem NEW TOPIC NEW POLL POST REPLY
busaisbetter
posted July 26, 2009 06:36 PM
battery problem
battery looses power at random. in the morning it is fine if i stop at store or gas station it just wont start. than fine again for few days. till samething happens all over.
do i need a new battery.
LAB3
posted July 26, 2009 06:51 PM
Check the battery cables to see if loose or dirty connections. Pull battery and have
it load tested.
FasterThanStink
posted July 26, 2009 07:17 PM
Check the connections first.
How old is it? Older than two years I would just get a new one.
That's what gets you.
posted July 26, 2009 07:42 PM
Dosent sound like the batt, sounds like the connections somewhere or a ground.
Bluebyyou
Gettin My Curve On
posted July 27, 2009 06:29 AM
As said above, make sure it has clean tight connections. A bad battery wouldn't occassionally get better on it's own.
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
posted July 27, 2009 07:30 AM
+1
also check your starter cct, and the cable on the starter.
If it continues, trry a new relay for the starter, as it may be the problem if the bike doesn't even try to enguage the starter.
0.24637484550476 seconds processing time
