BIKELAND > FORUMS > ZX-14.com > Thread: Re-doing the turbo stuff on re-install NEW TOPIC NEW POLL POST REPLY
JDC
posted July 24, 2009 01:23 PM        Edited By: JDC on 24 Jul 2009 21:25
Ok, got the allen head bolt drilled out on the turbo exhaust flange this morning and the exhaust pipe and turbo off.
I am going to ceramic coat the turbo, and I'd guess just the exhaust side, inside and out. Never ceramic coated anything yet. What do you all recommend, as in the pieces:
1. main exhaust side, inside and out, does that mean I need to remove the propellar, etc
2. middle smaller junction between intake and exhaust side as well to get ceramic coated?
3. is it worth having the exhaust coated in or out?
I have a turbo blanket I plan on using when this thing goes back on, and some 22K heat shield for the backside of the scavange pump, maybe oil lines as well.
I appreciate all your suggestions and info on the other topic, about the exhaust bolt being frozen in place. Once the exhaust pipe was off, that cut off bolt came out with finger turning only!
Some pics:
turbo actuator flange spot welded so will not re-install the actuator. Have been on waste gate for a bit, now just getting rid of the stuff and tidying up on the re-install.
the stink exhaust flange, top right which had one of the the allen head bolts. I hope to modify the flange to be able to use regular studs-n-nuts on the reinstall.
Any other suggestion are appreciated. I hope to get the things out to ceramic coating early next week.
kawasakijockey
posted July 24, 2009 01:58 PM
Why did you weld up the waste gate?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
JDC
posted July 24, 2009 02:05 PM        Edited By: JDC on 24 Jul 2009 22:06
Kawa,
I tac welded the actuator gate/port. I am using a waste gate, and they are redundant up to 8-9 PSI. The tack keeps that 'door' shut so I can now increase the PSI in the waste gate without worry of the actuator being over powered and opening. I think the actuator gate is only good to about 8-9 PSI.
I am thinking of playing with AV gas and PSI about 14 or a little under.
Compton
posted July 24, 2009 02:06 PM
dont coat the exhaust housing internally.
i'd just do the outside on the housing, same with the compressor side.
exhaust pipe do both.
b.w.
Compton
posted July 24, 2009 02:07 PM        Edited By: Compton on 24 Jul 2009 22:07
Kawa,
So you are saying you added an external wastegate to your kit, and are no longer using the integral wastegate on turbo?
b.w.
JDC
posted July 24, 2009 02:12 PM
Correct.
posted July 24, 2009 10:27 PM
My 2nd system from ATP is at the coaters right now, getting internal and external coating done.
JDC, you can not dissaseemble the turbo cartridge without loosing all of the ball bearings, Garret likes to keep business at home, so only a few Garret dealers have the tools to rbuild or dissassemble the double ball bearing turbo.
I had to grind down the external part of the internal wastgate actuator, so the rad would clear it....
JDC
posted July 25, 2009 06:17 AM        Edited By: JDC on 25 Jul 2009 14:24
Lyle,
Thanks for that heads up on the disassembly. I was worried some things may jump out. Did you disassemble it yourself?
There appear to be many coatings around. Lyle where are you having yours done at?
Yes, the pivot arm is so close. I have about 1/8" clearance, but will grind it down a bit before I put the piece back up, minus the actuator. I had though of cutting it completely off. but decided against it for future use.
Why are you on a second ATP system?
Also, I was thinking of putting some type of exhaust gasket material, probably the sheet type you can cut, between the header and turbo, and again between the turbo and exhaust, Harry said it was not needed, so I wonder if it would really just decompose and cause leaks down the road?
posted July 25, 2009 06:51 AM
The exhaust housing was already done for me at my request to ATP.
My header is being done locally, by a company called Top Gun Coatings
There are others though, swaintech and jet hot coatings also come to mind.
posted July 25, 2009 07:03 AM
The reason I am on my second ATP system, delayed 4 weeks, and completely pissed off......
the 1st header with external gate did not fit. Completely incompatible with the 2ndary balancer at the front of the block. Boost tube also interfered with the exhaust pipe on #4 cylinder
New one did not fit either, I had to modify it as well.
4 week delay including shipping and coating
JDC, did your turbo have a 3" compresssor inlet for the air fliter? Mine was machined down to 2.75" and my air filter in the kit doesn't fit, in fat K&N only makes 3-4 of them with 2.75" inlet.
-I get madder by the minute with this system, and the service was very complacent and too layed back for my taste.
-Having to argue and email 20 pictures didn't help either.
Jig my ass
-The blow off valve, and regulator looked like they played hackey sack with them too.
Then he doesn't know how to fill out a simple customs paperwork form, so i paid another $200 to get HIS work corrected including shipping,
He tried to weasel out of the work because its been in a box fro a year.
On top of the aggrivation, I get pedalled with additional expenses, increased delays, poor workmanship, lazy attitude,
Then I get lip service.
Its a small world. Talk is cheap.
I would rather pay him a visit than ever talk to him again.
They sent their junk to a Canadian thinking they could shove the shit off on the little guy.
The second header was built much much better than the first, but I thought I paid $5000 for a complete, proven, fitted system.
The 1st header was none of that, and the second had to have some mods to fit the head and wastegate.
posted July 25, 2009 07:07 AM        Edited By: dubious on 25 Jul 2009 15:13
Nevermind
I am getting intensely angry about all this again right now...
nothing nice to say....sooooo.............
JDC
posted July 25, 2009 07:29 AM        Edited By: JDC on 25 Jul 2009 15:35
Lyle, Mine is 2 3/4 as well. Why do you say macnined down? 2 3/4" is not standard for a GT 30?
http://www.turbobygarrett.com/turbobygarrett/images/catalog/Turbochargers/gt30_pdfs/Garrett_GT3071R_new.pdf
In a box at his shop...? I dont understand what what has to do with your new order and the warranty that you get?
I agree with that 100%. He used my bike to remake his jig for the header, as his first jig was lost. I feel that the header was done well. A very small grind on one tab and it went in nicely.
Lyle, I recall some of the issues, and I'm sorry that the problems have continued. There is no excuse for unprofessional beharior, worksmanship or service, and especially at the prices paid for the kit. Overall I guess I have been blessed with no major issues other than the exhaust getting whacked for more $, and it being pieced together and welded rather than mandrell bent, and not the size I was told it would be. Harry said 2 1/4" would be too small an exhaust system and would choke off the power, so I'd need a 2 1/2 inch setup. He ended up putting on a 2 1/4" system. I was pissed as well X 2 for both deceptions/mistruths.
Where are you getting your ceramic coating done and did you disassemble your turbo yourself for the coating process?
JDC
posted July 25, 2009 07:37 AM
Yes, not worth the agrivation....
Compton
posted July 25, 2009 08:16 AM
this is why i'm building my kit for me, and around what i want. i'll have nobody to blame but e on anything!!
b.w.
Stu64
posted July 25, 2009 10:13 AM
What part number is the GT3071r ?
I am thinking of piecing together a homemade kit for my bike.
I thought the ATP kit used a 4" compressor housing?
Also what brand blow off valve does it use? Stu.
JDC
posted July 25, 2009 10:26 AM
Compton,
good idea. Probably the most work will be fabbing up the header assembly.
I dont know the part number but the link is at top.
the overall inlet housing is about 6" dia
blow off - attached to left side airbox inlet -"Spa Turbo"
I am using a Tial waste gate and not the built in actuator
Compton
posted July 25, 2009 01:47 PM
i'm using a garrett GT30-76r, adams oil pan, Race Proven Motors 38mm wastegate, HKS SSQBOV, my fuel system, and a couple of other little tricks.
b.w.
Stu64
posted July 25, 2009 02:01 PM
JDC, would you want to sell the original waste gate actuator? I would be interested.
Thanks...Stu.
Stu64
posted July 25, 2009 02:07 PM
Compton, keep us posted on your set-up,pictures too!
The hardest part for me will be making the manifold.
Can't understand why these places won't sell just the manifold,some people cant afford to spend $5 G's so why not get what you can by selling parts.
JDC
? Please let me consider the idea. I'll get back to you here Sun or Monday.
Compton
posted July 25, 2009 03:20 PM
making the manifold will be the easiest part! ha
b.w.
posted July 25, 2009 08:23 PM        Edited By: dubious on 26 Jul 2009 04:49
Thanks...Stu.
Stu, if your interested i will sell you my turbo, maybe the header too come winter
It has been fixed I will post picks after its coated
I would be selling it quite cheap.
Stu64
posted July 26, 2009 03:04 AM        Edited By: Stu64 on 26 Jul 2009 11:27
Thanks...Stu.
Listening...... very interested.... email me and to the rest of you guys i've got 1st dibs....LOL.
scobble@wi.rr.com
Bad in Black
posted July 26, 2009 08:46 PM
Wow, I almost went with ATP for my turbo kit too. I'm glad I didn't get involved in a goat-rope with those guys. I did talk to Harry tho, and I have to admit he didn't sound too enthusiastic.
iflyems
posted July 27, 2009 08:11 AM
He always sounds that way, that's just his normal tone.
0.23036813735962 seconds processing time
