BIKELAND > FORUMS > ZX-14.com > Thread: auto tune help NEW TOPIC NEW POLL POST REPLY
starchild
posted July 19, 2009 02:23 PM
auto tune help
hey guys i did the search but found nothing to help with my problem.set the auto tune up simple enough, but i cant get the pcv to read the auto tune. there is no af/ register at all. tried the sensor test and by the test it works . still no acknowlegement from the pc. please help me out. when i ran the auto tune my bike sputtered and acted if it was real lean. i disconnected the auto tune and it ran fine. thanks.
jay
AcadianaZX
Advertiser
posted July 19, 2009 11:09 PM
Click on Power Commander Tools in the software. If it's available it will be highlited. Do you have a base map to start with? Also you will have to block the clean air hose on the right side under the air box. The clean air system will make the auto tune overly rich. I pluged it and totally got rid of my decel pop with my Muzzy M14 exhaust. In my Schnitz base map I only noticed very little changes below 4500 rpm when I clicked get map in the software. Also maybe you could take some picks to help John Bull with his PCV harness. I have a little over a week before I get back home. Any way hope this helps. Let me know if you need a map.
johnbull
posted July 20, 2009 06:20 AM
I seem to remember that when I had set mine up to the autotune, I first had to calibrate the Throttle position sensor to the PCV. It mentions this in the instructions, have you done it yet?
Would appreciate it if you could take some pics of your PCV connectors so that I can see which colour wires go where.
Cheers
John Bul Racing. Malta.
AcadianaZX
Advertiser
posted July 22, 2009 01:10 AM
Jay, Any luck?
starchild
posted July 22, 2009 12:24 PM
hey thanks everyone finally got through to dynojet they told me i did not plug the two remaining ports that are open. they send two plugs that are supposed to close any open ports. and if they are open it will not read the pcv. i think that is what they are trying to explain to a guy that sucks at anything electrical
jay
johnbull
posted July 27, 2009 06:12 AM
Haha, glad you sorted it out anyway Jay.
0.26928687095642 seconds processing time
