BIKELAND > FORUMS > ZX-14.com > Thread: How to install MPS air shifter on zx14 NEW TOPIC NEW POLL POST REPLY
Jsteal
posted July 23, 2009 02:21 PM
I'M new to working on bikes and help installing my air shifter the directions are confusing to me. Can someone help me?
Jman
1badzx12r
posted July 23, 2009 02:23 PM
good luck .. cause i can't type it better than the instructions .. is it the MPS auto shift with kill ..
Jsteal
posted July 23, 2009 02:34 PM
Yes
Jman
Wheelie
Old Man
posted July 23, 2009 02:40 PM
pay someone to install it
wee
1badzx12r
posted July 23, 2009 04:09 PM        Edited By: 1badzx12r on 24 Jul 2009 00:11
good choice .. works flawless ..i got 1 on my bike ..
unless your putting a relay in-line ..its really simple ..
Jsteal
posted July 23, 2009 05:12 PM
Can't figure out what to wire the compressor to so it will run when the toggle switch is turned on
Jman
14nooby
posted July 23, 2009 05:35 PM
Call Todd @mps. I installed the low pressure system with no compressor. Todd is great.
1badzx12r
posted July 24, 2009 04:48 AM
screw that toogle switch shit and get a pressure switch for your volume tank .. i run a 95 to 125lbs ..i'll try findind it and post back to you ..
Jsteal
posted July 24, 2009 04:52 AM
Ok, get back to me i'll try a pressure switch
Jman
1badzx12r
posted July 24, 2009 04:53 AM        Edited By: 1badzx12r on 24 Jul 2009 12:56
http://cgi.ebay.com/ebaymotors/Air-Pressure-Switch-4-Train-Horn-Compressor-110-PSI_W0QQitemZ370228758517QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item56335a87f5&_trksid=p4506.c0.m245&_trkparms=65%3A12%7C39%3A1%7C72%3A1171
this is not the exact switch i used
i broke the ground wire off on the switch and ran power to compressor
1badzx12r
posted July 24, 2009 04:58 AM        Edited By: 1badzx12r on 24 Jul 2009 12:59
this is were i got mine 125lb to 95lbs.. i don't know if its better than the one above but it works flawless
http://cgi.ebay.com/ebaymotors/150-PSI-Air-Pressure-Switch-Horn-Suspension-Compressor_W0QQitemZ270428432102QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item3ef6ca66e6&_trksid=p4506.c0.m245&_trkparms=65%3A12%7C39%3A1%7C72%3A1171
Jsteal
posted July 24, 2009 05:10 AM
Does it matter what type of compressor I use with the pressure switch
Jman
1badzx12r
posted July 24, 2009 05:29 AM        Edited By: 1badzx12r on 24 Jul 2009 13:30
NO..i purchased a 10.00 wal-mart 12 volt tire compressor and unshelled it until i got to the compressor and used that ..been on bike for 1.5 years now with 1000's of shifts
Jsteal
posted July 24, 2009 06:29 AM
I'm going to give this another shot. I will be back to say if it worked. I will give Todd at mps a call too. Thanks for the help. If anyone has a ideal drop me a line.
Jman
Big_T112
posted July 24, 2009 08:43 AM
I ran mine off of what was the power wire for the tag light. I also used a switch swapper for the horn and it was a breeze. I didn't want my bottle hanging off the side so I took the tool kit box off and put the bottle there. I also tapped the motor mount bolt so I could thread an 8mm bolt in it to hold the air cylinder. saves on buying the mount. works like a champ.
Jsteal
posted July 24, 2009 01:41 PM
U ran the compressor off the tag light right.
Jman
1badzx12r
posted July 24, 2009 08:18 PM
yes i did too.. i wanted a keyed source
Big_T112
posted July 24, 2009 11:57 PM
sure did.
0.27015900611877 seconds processing time
