BIKELAND > FORUMS > ZX-14.com > Thread: Rattle at 3-4k rpm? NEW TOPIC NEW POLL POST REPLY
silvrevo
posted July 22, 2009 12:36 PM
Rattle at 3-4k rpm?
Hi guys
I just got an 2008 zx14,, have about 350 miles on it. And around 3-4k rpm's I hear what wounds like BB's rattleing in a soup can.
After a little research it could be the chain cam tensioner?
What else might it be? Hopfully simple...
I dont want to have issues with this bike,, I really love it.
I think after 7-8krpm's it settles out,, and or I cant hear it anymore.
All is stock.
Advice? Same issue? Please respond
in
Advance!!!!!!
'08 zx14
posted July 22, 2009 12:39 PM
what throttle position? What fuel you using?
Thats exactly what detonation sounds like, and shit fuel is more prone to detonating at wfo throttle, in lower RPM's , under more load and less RPM
busaisbetter
posted July 22, 2009 01:01 PM
if it is like a buzz and humming noise than remove the windscreen you will see tip over sensor - put zip tie around the rubbers really tight and you are good to go.
zx-14brent
posted July 22, 2009 01:08 PM
Sounds to me like it is the Tip Over Sensor located behind the windscreen. The TOS on my 2008 was so loud that it bothered me even after i put on a much louder full Yosh exhaust system. The spacers used to mount it were to long so i ground them down a bit and I wrapped the TOS in foam and thats the last i heard from it.
busaisbetter
posted July 22, 2009 01:18 PM
cam tensioner is that another inherited problem with stock bike?
posted July 22, 2009 01:20 PM
Sounds like the tipover switch to me.
posted July 22, 2009 01:22 PM
yeah, its been so long I forgot about that.... I just added a few more washers so it was tight on the bracket.
LOL
NeverKnow
posted July 22, 2009 08:07 PM
+1
silvrevo
posted July 23, 2009 10:39 AM
Il zipp tie those and let you guys know.
I just put on a zero gravity st. screen and noticed that those two things under the screen were really really loose,,, must be the tip over sensors right?
'08 zx14
busaisbetter
posted July 23, 2009 10:51 AM
problem with the sensor is that even with screws fully tighten it is able to vibrate. .... so take a small zip tie and put it on top of rubber - dig it in there. zip tie goes vertically. around the sensor i hope that is clear. WISH i had a pic it would be lot easier to explain that way.
Rideharder
posted July 23, 2009 10:59 AM
Once it heats up does it stop? Do you have an aftermarket exhaust?
  Ignore this member    Click here to visit Rideharder's homepage.
busaisbetter
posted July 23, 2009 11:04 AM        Edited By: busaisbetter on 23 Jul 2009 19:27
see the yellow highlight thats where zip tie goes.
silvrevo
posted July 23, 2009 11:33 AM
So just one zip tie? And it goes around the waist area of the yellow lines?
Good thanks BusaK... I will get this worked out tonight.
Really as long as that is what it is,,, I dont really care about the rattling.
I had my windscreen off the other day and put a zero gravity st on,, this will give me the time to paint the bottom of it black,, you can see thru it and the wires look like crap.
Thanks. I will keep you posted.
'08 zx14
busaisbetter
posted July 23, 2009 11:38 AM        Edited By: busaisbetter on 23 Jul 2009 19:39
2 zipp ties; one on each side. i hear you with this bike there are few annoying things.
other things you have to look forward to is oil seep from the valves - no big deal.
get extended warranty if you are worried. - cheap on ebay.
LAB3
posted July 24, 2009 07:09 AM
Thanks, Picture was a Plus.
silvrevo
posted July 24, 2009 08:33 AM
Hi guys ,, Im pretty sure it the tip over sensor,, Im going to try to tighten it up,, zipp ties didnt do much.
As long as it not in the motor,, Im fine with it.
'08 zx14
0.27684092521667 seconds processing time
