BIKELAND > FORUMS > ZX-14.com > Thread: i need help.. a bazzaz ? NEW TOPIC NEW POLL POST REPLY
1badzx12r
posted July 16, 2009 04:35 AM        Edited By: 1badzx12r on 16 Jul 2009 12:36
ok most time i just call support .. but i'm gonna see how smart someone is with these units ..
bazzaz z-fi and a z-amf unit .. ok i was reading the whole 7 page manual and nowhere does it go into detail to state how to adjust map down low ..only info was self mapping is activated after 5% tps and over 3k rpm .. thats fine but how do you input fuel changes down low ..i tried clicking on box and manually input a fuel number ..but it doesn't work ..i read the manual twice in that category and it says you can insert fuel changes manually ..
now why i'm want to change low(idle) fuel map is at idle the 02 sensor is reading 16.7 off the scale .. but bike idles fine and when it revs up it drops to around 13.0 a/f.. which is ok
this is my first bazzaz unit to own and i did not purchase it ..it was already installed on bike
1badzx12r
posted July 16, 2009 04:40 AM        Edited By: 1badzx12r on 16 Jul 2009 12:42
this is copy from the online manual
(1) FUEL ADJUSTMENT MAP
a) Enter +/- % fuel adjustments directly into cells (NOTE: Adjustments are saved directly into the ZFI memory)
b) Use the mouse to select a range of cells to fill with the same value or to change by a fixed value
c) Use the page up / page down keys to add or remove fuel
maybe there something wrong with the software i installed and need to reinstall it .. but i can not get fuel changes manually
posted July 16, 2009 04:43 AM        Edited By: Shane661 on 16 Jul 2009 12:43
You suck. (sorry, couldn't resist)
1badzx12r
i know it . but bazzaz don't know it .
posted July 16, 2009 04:57 AM
Self mapping is sweet !!!
why add fuel down low, if too rich then it wont idle smooth...I would leave it alone
1badzx12r
posted July 16, 2009 06:03 AM        Edited By: 1badzx12r on 16 Jul 2009 14:04
CR i learnt from my turbo bike that to high of an a/f down low makes it idle erratic and stumbles from take off ..
and my new bike with the bazzaz does just that at take-off from a redlite ..goes out about 10 feet and stumbles (falls flat ) before it catches and go ..
and yes i like the self mapping unit ..
Ninja ZX-14
posted July 16, 2009 06:20 AM
Yeah but I know it
Ninja 14
Wheelie
Old Man
posted July 16, 2009 07:27 AM
rookie
wee
LAB3
posted July 16, 2009 07:32 AM
I have a Bazzaz Z-Fi kit and the AFM unit that I have not installed yet. Post what you find out
on this problem.
LAB3
posted July 16, 2009 07:34 AM
rookie
wee
Wee can you program a Bazzaz?
1badzx12r
posted July 16, 2009 09:08 AM
on this problem.
theres a nice long write up on the bazzaz and its problems on gixxer .com .. but i'm getting ready to call bazzaz support.. cause from the postings on gixxer .com it seems to be a job to tune under 3000 rpm ..and it was never real clear cut on how to
1badzx12r
posted July 16, 2009 09:09 AM
rookie
wee
gotta learn to crawl before you can walk ....
LAB3
posted July 16, 2009 09:16 AM
on this problem.
Thanks, I got mine from Lyle so if I have aproblem I will try Bazzaz support then I will email
Dubious to help this Rookie :-)
JDC
posted July 16, 2009 11:14 AM        Edited By: JDC on 16 Jul 2009 19:17
"input fuel changes down low "
go into the map, select the cell/cells you want, below 3K, and input your percent change there. I largely have made my 1-3K based upon the idle A/F for a 13.1.
seems to work fine.
That method worked for non-turbo and turbo as well. I only really start a more rich 'turbo' A/F from 4K (at 13.1) ramping up to 6K (12.5) where it remains most rich to top.
1badzx12r
posted July 16, 2009 11:24 AM
that what how i taught it should work JDC.. But for some reason i can't get the cell block to stay hi-lited for input ...as soon as i hit the key to put a number in ...it re-hi-lites at a cell next to the 1 i'm trying to put A/F numbers into ..
but i just got done putting the exhaust back on and will try tuning below 3 k again ..
JDC
posted July 16, 2009 02:07 PM
hmmm. I know once the software would not intake input..... very weird.
I ended up reinstalling and then was all ok for me.
posted July 16, 2009 02:43 PM
Hi Guys,
been away for a few days with familly.
Robert,
With the ZX10 unit I installed, All I had to do was highlight the cell as JDC said, and it would take what ever input I put in it as JDC did.
I do not know what else to tell you, but to work with Bazzaz tech support.
I know its a useless answer for you, but thats all I have.
Sorry,
Lyle
1badzx12r
posted July 16, 2009 02:49 PM
i figure it was the software guys ..but i don't have a cd ..i had bazzaz send me it via email ..i couldn't get it to open from their site download ..
posted July 16, 2009 02:53 PM
JDC
posted July 16, 2009 04:37 PM
1bad,
I downloaded their software and put it on rapid for u.
http://rapidshare.com/files/256658781/ZFI-Mapper.zip
1badzx12r
posted July 16, 2009 06:27 PM
THANKS JD ..
1badzx12r
posted July 21, 2009 04:51 AM
ok guys even with JDC File i couldn't get it to work .. so i borrowed a CD from a freind .then uninstalled and reloaded for the 14th time .. and it works great now .. something was just fukk-up in my software downloads ..
LAB3 you will like the set-up .. it was worth all the trouble i had to get it running ..
LAB3
posted July 21, 2009 05:50 AM
Thanks, glad you have it working. Lyle sent everything, I will be carefull with the CD :-)
Wheelie
Old Man
posted July 21, 2009 08:43 AM
rookie
wee
sorry for the late reply, email me mrwheelie@tx.rr.com
wee
LAB3
posted July 21, 2009 01:39 PM        Edited By: LAB3 on 21 Jul 2009 22:36
rookie
wee
wee
OK,
0.22563791275024 seconds processing time
