BIKELAND > FORUMS > ZX-14.com > Thread: Crank case hose on turbo'd bike NEW TOPIC NEW POLL POST REPLY
JDC
posted July 01, 2009 06:50 PM        Edited By: JDC on 2 Jul 2009 02:54
I've been venting this hose out and down the side, then just a tad under the backside of the oil pan. That got the oil out onto the street/ground. Before this routing and removing the crank internal tube, I was getting a lot of oil all over the area the hose vented. There are blue oil fumes (smoke?) from this hose.
I was thinking making a hose port on the back side of the filter to the tubto inlet and routing this hose to that. Ala, no more blue fumes, but there would be a very small amount of oil heading into the inlet of the turbo.
Do you all think this would cause any problems?
posted July 01, 2009 07:03 PM
I did that to my turbo zrx1200 and it worked great ... What i did was get a filter with two nipples ( one on each end ) Run the line from the crank case to the filter and then to the big filter on the turbo ... No more stinky fumes when i pulled up to a stop sign ..
JDC
posted July 01, 2009 07:06 PM        Edited By: JDC on 2 Jul 2009 03:06
Smokin...
Interesting.
What is the purpose of the in-between filter?
posted July 01, 2009 07:17 PM
Smokin...
Interesting.
If it was a line right to the crank case to turbo filter the suction from the turbo would suck oil from the crank cases ...with a open filter in the line it would only suck the fumes mixed with a little fresh air ...
posted July 01, 2009 09:40 PM
JDC , I have some questions for ya,
can you hit my email?
eldubois at telus dot net
thanks
JDC
posted July 02, 2009 02:08 AM
Smokin,
Great idea.
Thanks.
JDC
posted July 02, 2009 02:09 AM
dubious,
done.
BIKELAND > FORUMS > ZX-14.com > Thread: Crank case hose on turbo\'d bike NEW TOPIC NEW POLL POST REPLY
0.23632311820984 seconds processing time
