BIKELAND > FORUMS > ZX-14.com > Thread: Why Is My 14 Burning So Much Gas NEW TOPIC NEW POLL POST REPLY
dhobbs74
posted June 29, 2009 03:02 AM
Something is definately wrong with that bike. I filled it up yesterday an headed to one of my friends house. Now keep in mind that I was riding on I-40 In NC cruising around 80-85mph at times. Before i could go around 150miles before my gas light would come on. Now it has the same map, stock sprockets and everything, I haven't changed a dam thing on the bike. Well yesterday i had only rode 80 miles and my dam tank was empty, I had to pull off the interstate to get gas. WHAT THE HELL IS GOING ON?? Something else I've noticed also is that I use to could dump the clutch in 2nd gear and do a pretty long burnout. Now when I try it it might turn the tire over maybe one time then it grabs and go. Something is not right. I do know that I can hear my cam chain rattling but I dont know if that has anything to do with it or not. Someone told me that I might have a couple of partially fouled plugs or something. Do you guys have any idea what might be wrong??
Bigbore4
posted June 29, 2009 03:17 AM
"Something else I've noticed also is that I use to could dump the clutch in 2nd gear and do a pretty long burnout. Now when I try it it might turn the tire over maybe one time then it grabs and go. Something is not right. I do know "
You are either trying to be funny or your just retarded!
Bigbore4
posted June 29, 2009 03:18 AM
"Do you guys have any idea what might be wrong?? "
Sure, it's without a doubt, the operator.
BobC
posted June 29, 2009 03:40 AM
The bike has an Average mpg display and will also show Instantaneous mpg and Range. You ought to be able to see where it's using fuel and under what conditions.
My bike averages around 45mpg at 85mph cruising on a constant throttle. On the other hand it drops into single figures on WOT at maximum rpm. Just depends how it's being ridden.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
Superman T
posted June 29, 2009 03:47 AM
80 miles on a tank of gas??? Wow! You difinately have something wrong.... how many miles and what year do you have? Are you still covered under warranty? Besides the long 2nd gear burnouts of the past(I wouldn't dog my bike like that repeatedly but to each his own), have you seen any other power reductions(1st gear power,3rd-5th gear pulls)? Do you have an aftermarket pipe? Power commander?
Bigbore4
posted June 29, 2009 03:51 AM
Honestly, guys that ride like this really don't deserve to have bikes like the 14.
Anyone that dumps the clutch in 2nd to see how big a burnout he can do, is a moron.
The dipshit has obviously fried the clutch and doesn't have enough mechanical aptitude to
figure it out.
dhobbs74
posted June 29, 2009 04:01 AM
Thanks for the only sensible reply and not the smart ass reply like these other assholes. Geez you can't even ask a simple question, I thought this is what this forum was for but anyway as far as the burnouts I dont do a lot of those, I might do one every blue moon, tires are too expensive. I have an 06 with 8000 miles, fully muzzy exaust, power commander. I think im going to check the plugs and just take it to get a custom map because the one in it now is a generic map I got off the Power Commander website.
dhobbs74
posted June 29, 2009 04:07 AM
figure it out.
Fuck you!! If you can't respond in a respectful manner than keep your guydam mouth shut bitch!! I thought the purpose of this forums were to talk about zx-14's and share resources and to gain knowledge of our machines. I've been riding bikes for 15 years mutherfucker I was just asking a dam question. Ok maybe it was a dumb question to you but to me im just trying to figure out whats going on. If you can't be respectful and use this forum for it's purpose then maybe you shouldn't be posting.
Bigbore4
posted June 29, 2009 04:24 AM
Like I said pal, Anyone that dumps the clutch in 2nd is a moron.
And such harsh language too! Maybe you should have yo momma wash your mouth out with soap. Have fun fixing yo bike.
dhobbs74
posted June 29, 2009 04:31 AM
Maybe your mom should have taught you that if you can't say anything nice then don't say anything at all punk! Have fun learning how to be respectful to others
Superman T
dhobbs74- It's cool, it takes all kind to make the world turn... You'll find personalities on both sides of opinions(optimist/ pessimist). But ultimately this is your bike- your problem- your money to fix. So if you need info, request as needed.... There are still some other questions that may help to further help diagnose your problem.
Now keep in mind that I was riding on I-40 In NC cruising around 80-85mph at times(your quote). Can you remember what RPM were you humming at? What type of fuel did you put in(octane?)?
Bigbore4
posted June 29, 2009 04:42 AM
Ok, maybe Moron was a bit harsh.
How bout Knucklehead?
You've obviously F'd up your bike. These things are to heavy to do 2nd gear clutch drops, even if you're a flyweight. 1st is plenty impressive.
I would look at the clutch, as it may be slipping in the higher gears and you may not notice it.
If you had a couple fouled plugs, it would fall flat o it's face.
dhobbs74
posted June 29, 2009 04:52 AM
I understand that but to be honest i've only maybe done 3-4 burnouts in the whole two years that I've had it. I normally dont do burnouts because I think it's not good for a bike but we all are guilty of it at some time or another. I have noticed that it idles very rough at initial startup until about a min and then it clears up. It never did that before. It's always had a decel pop at a certain rpm but latetly it seems it's gotten worse. Maybe I need to check the clutches but dam it's only got 8000 miles on it and I dont ride it hard, I might do a couple roll on's here and there but thats about it.
Bigbore4
posted June 29, 2009 04:59 AM
If the decel pop has gotten worse, it's a "rich" sign. If you've been riding in dusty conditions, it's possible the air filter is really restricted. The rough idle on startup could be something like a MAP sensor, or if the fuel quality is suspect, you may have some leaky injectors.
Best bet is find a decent mechanic, whether at a dealer or an independent. Someone that has the abilty to plug into it and see what the system is doing. Good luck.
Superman T
posted June 29, 2009 05:16 AM
yeah and stop doin 2nd gear burnouts! J/K
pissear
Professional Cockis Slap Peer
posted June 29, 2009 06:41 AM        Edited By: pissear on 29 Jun 2009 14:42
Has the temp and ambient changed during your better mileage, months/weaks ago? You might remove the hot side (+) of the PC unit. Fill the tank, take it for a ride, burn 2nd to see if the fuel trim is too rich that fluffed the power ...
Ass far as 2nd gear burnouts... I'll slap that fucker all up is knock him off his 14 is why that guy cannot steer away from that ditch in 2nd gear is tell others what to do to or how to ride their own bike in any gear.
So shad up, telling others how to treat their bike. Go wipe the sweat off your mother's testickles if you have to make comments. Come get some, hobb knob big boring!
GHOSTMAN
posted June 29, 2009 07:15 AM        Edited By: GHOSTMAN on 29 Jun 2009 15:16
Dammit Bigbore!!!! See whatcha did!?!
I'm There Whether You See Me Or Not.
117 in a 30
posted June 29, 2009 07:34 AM
+1
mike1024
posted June 29, 2009 07:42 AM        Edited By: mike1024 on 29 Jun 2009 15:54
figure it out.
I have to agree with this statement. Get a supermoto bike or a beater. Youre gonna destroy a perfectly good bike doing dumbass squid stuff like that. The ZX14 is not gonna take big fat burnouts at 9000RPM and sip gasoline. Its a gulper. Ill bet your flies are out, and your around town mileage will suffer as a result. Straight line, constant speed, at 4k rpms in 6th gear I get about 45-48mph consistently. I have 25000 miles on my zx14. I have K&N air filter, new plugs, alien head exhaust, no flies, 42psi BTO 21 tires.
Ride it like a dope, get bad mileage. Ride it like an old person, get 50+mpg. On average, I get about 140 miles per tank BEFORE the stupid fuel empty light goes on, which I never trust.
Keep safe, ride smart, and respect the 170+HP thing betweeen your legs. Drive with your brain, not your balls, and you will ride a long, long, time.
Everyone rides like a moron sometime. I do it daily on my DRZ400SM supermoto. Every day, I do a stoppie, a wheelie, I back it in, and do jumps in rises in the road. On that kind of bike, its ok. Would I do it on a sportbike? NEVER!!!! The abuse is much worse on a sportbike!
Peace!
Bigbore4
posted June 29, 2009 05:21 PM
Yea, looks like Pissear and 117 crawled out from under their rock.
This forum is good for a laugh sometimes isn't it?
FIFTH
The Magnificent Bastard
posted June 29, 2009 05:46 PM
have you tried re-installing the map? mine corrupts for some reason after a few weeks. I re-install my map and I am good to go.....
dcjens
Wet side of Washington
posted June 29, 2009 05:50 PM
with the idiot gas gauge I consistently get 34 mpg (average) 160+range when the psycho pump comes on. if I use a calculator at the pump I get 34. My speedo healer is dead on by the GPS speedwise. I definetly get better mpg over 75 mph steady speed. I think our tank is 5.9x 34=200.6 per tank empty and pushing it. Let's hear some others (although I dont care much about MPG) damn!! somebody is PMS'ing!!!!!
Black 06
FastestBusaAround
I eat Fish...
posted June 29, 2009 07:00 PM
I get no more than 120-130 to a tank...but, I ride it at 6-8K all day long...have 16/43's/pipe/stretch...PCIII and do 2nd and 3rd gear burnouts while rolling at speeds...80 to a tank seems just really wrong. Seems like there's a big fucking gas leak somewhere. Hell, even drag racing would get better than that...
FYYFF!!!
LLcooljebb
Upgrade I Must
posted June 29, 2009 08:23 PM
Could an injector be stuck open...I don't have any experience with that, but mabey someone else will have some input...otherwise, +1 on FIFTH's map reload.
"no time to be void or save up on life
you got to spend it all.."
Flame On
Fuel Air & Spark
posted June 29, 2009 08:53 PM
I have close to 2 gallons of gas left when the fuel light goes on it might be our fuel tank sensor 6.1 gallon tank and can only add a little over 4 at the pump when fuel light flashes
77 RD 400
80 GS1000 GT
06 ZX14
0.26151299476624 seconds processing time
