BIKELAND > FORUMS > ZX-14.com > Thread: How to install pc3 NEW TOPIC NEW POLL POST REPLY
robzx14
posted June 29, 2009 01:52 PM
How to install pc3
Have 06zx14r how do you hook up power commander
14nooby
posted June 29, 2009 01:55 PM
It should come with simple directions. Took me about 1 hour to install. I saw that brocks was running a free pc3 with purchase of exhaust. Now would be the time to get your exhaust if thats still going on.
Douglas Home
posted June 29, 2009 02:06 PM
Lots have had earthing problems , save yourself the trouble and run a wire to the main
earth bolt on the frame under the right hand side battery cover
Doug Mackay Australia
14nooby
posted June 29, 2009 02:10 PM
Douglas,
Got you on the earthing thing. Robzx14 earthing means grounding. Yes Douglas is correct when installing make sure you have a good ground. Clean the paint off of the frame with a wire brush so you get a good ground.
zxbob
posted June 29, 2009 02:17 PM
The connector under the left foreman grill is a bit of a "p.i.t.a."
Good ground is a must !!
Bob
posted June 29, 2009 02:59 PM
yeah i got screwed following dynojet's directions with my 06 "waterbottle" bolt
WARBIRD
posted June 29, 2009 03:18 PM
Lengthen the ground wire and attach it to the negative battery terminal.............
I'd Rather Be Roadracing.
zxbob
posted June 29, 2009 03:19 PM
... you and many others !
Bob
pazx14rider
posted June 29, 2009 03:44 PM
+1
derpie
Dont judge a book by its cover
posted June 29, 2009 08:29 PM
Hey I'm still using this spot with no problems but I locktited the bolt.
epd345
posted July 01, 2009 04:52 PM
Im still using the coolent bottle bolt with no problems. Just put a washer on both sides.
robzx14
posted July 05, 2009 11:29 AM
Thanks pc installed bike runs strong i rode saturday and noticed i get better gas mileage does not sound right .
0.26324701309204 seconds processing time
