BIKELAND > FORUMS > ZX-14.com > Thread: Differences between '06 '07 - '08 '09 NEW TOPIC NEW POLL POST REPLY
silvrevo
posted July 01, 2009 02:10 PM
Can someone run down what has changed on the bikes over its 4 years?
Thanks in advance
'08 zx14
14nooby
posted July 01, 2009 02:28 PM
Did you try the search feature? I saw this the other week. I know of a couple differences and here they are.
- 08-09 bigger fuel injectors
- 08-09 butterflys open quicker (better low end throttle response)
- 08-09 has a lower profile fuel pump which won't hit the swingarm when lowered
- cam chain adjuster is better on the 08-09
- Metal air filter cover on 08-09
I am sure there is more but can't think right now
posted July 01, 2009 03:01 PM
Different Pistons..
Thicker noise paddings in places..
Main ground location moved.
Valve cover is different..
Header is larger as well as the mufflers..
Head porting, better flow ( can't prove this ) .
posted July 01, 2009 03:09 PM
they changed the way they casted the frames, to reduce failures from overtorquing. also making them slightly heavier. the 08,09 have cats in the exhaust , 06,07 didn't.
bruno nadeau
posted July 01, 2009 03:34 PM
all of the above+ECU+wiring harnes+dash display+radiator fan not shure (sound different)gear position display work fine in my 09.after 4000 KM on my 09 i can say that the bike is a little betther than my 06.not days and night but betther.stock bike+yoshimura R77 full.
bruno nadeau
posted July 01, 2009 04:10 PM
Different pistons and valve cover?
Does the valve cover look different for any reason other than air injection changes?
posted July 01, 2009 04:37 PM
No the valve cover looks the same on the outside ..But on the inside it has some kind of sound damping to cover up piston and valve train noise .. On the pistons they changed the skirt to cut down noise ..It's still a slipper type but i think the made the skirt a bit larger ..
ZX11D
Internet Police
posted July 01, 2009 07:36 PM
I believe similar noise reduction provisions are also made to the cam chain chamber.
'94 ZX-11
'07 ZX-14
Compton
posted July 02, 2009 02:59 AM
fuel tanks are different. fuel pumps, not just the housing, but the pump is different too.
b.w.
posted July 02, 2009 03:03 AM
08-09 have smoother throttle responce with more low end grunt, tip over switch same place as zx12s with same rattle...
silvrevo
posted July 03, 2009 12:11 PM
Thanks guys,, thats a hand full !!!!!!
I just picked up a 2008 metalic midnight mettalic blue....Runs like a magic carpet!!!!
Ill be around
latters
'08 zx14
johnbull
posted July 04, 2009 08:33 AM
Cheers guys, thanks for the info.
Can anybody confirm whether the 06 headers fit the 08/09 head??? I ask this because I had just bought a muzzy M14 header for my 06 engine before I blew it and I hope it matches the 08/09 engine which I have on the way.
Also I have heard many people mention 8 injectors on the new model, is this true?
John Bul Racing. Malta.
bruno nadeau
posted July 04, 2009 08:46 AM
injector are not the same but still 4 .i just buy a yoshimura R77 full it fit 06 07 08 09.slip on 06 07 dont fit 08 09 because of the different headers outlet size.
bruno nadeau
posted July 04, 2009 10:16 AM
Smokin put the exhaust from his 06 on the 09, so they must fit.
The new busa has 8 injectors, the zx14 has always and still has 4 injectors
kawasakijockey
posted July 04, 2009 11:16 AM        Edited By: kawasakijockey on 4 Jul 2009 19:17
Different Pistons..
Motorcyclist or CycleWorld had a write-up on the 08 before production and they stated there was a slight change in the head porting or port angle since it was getting different fuel injectors. Nowhere else has there been any mention of it so I kind of forgot about it. You may be right about that Smokin. I will try to find that issue if it is still here and post quote what it reads.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
kawasakijockey
posted July 04, 2009 11:41 AM
Found it! Motorcyclist Feb 2008 page 51. Word for word quote below..
" The cylinder head is revised, as is it's cover, and the secondary air ports (which inject clean air into the exhaust, leaning it out) are 20 percent bigger. The internals of the exhaust pipes have been dialed in, the header connector pipe is 75 percent bigger while a third catalyzer has been wedged in there somewhere. Intake porting has been fettled, and the reason for the obvious low-end boost is an increased spray angle for the sub-throttle injectors, from 15 to 20 degrees, sending atomized fuel over a wider area."
2007 ZX-14
1.38 60ft
9.03 @ 149mph
bigwil
06 zx 14 turbo stage 3
posted July 04, 2009 01:16 PM
header will fitt 06 to 09 only if you use a stock header you will have to use same year pipes you can put a 09 on a 06 and a the only diffrence is were they go together so yes the muzzy will fit
FWI injectors are the same size they just spray widder more fuel efficiant
bigwil// going fast aint easy so turbo it
bruno nadeau
posted July 04, 2009 01:35 PM
cylinder head part number are different betwen 06 and 09.
bruno nadeau
posted July 04, 2009 02:06 PM
I put my 06 Brocks pipe on my 09 ... seems to work fine ..You will have no problem using your Muzzy pipe on your new engine.. P/C Maps will be different , so you will need to remap or custom tune your new engine ..
FastestBusaAround
I eat Fish...
posted July 04, 2009 02:18 PM
Well - I can tell you that my 08 has more low end grunt than my 06 did, and the 06 was insane as well.
FYYFF!!!
johnbull
posted July 04, 2009 03:11 PM
Cheers for confirming that the exhaust headers will fit guys.
Luckily when the car caught fire it didnt manage to get at the PC5, but it did get at the connectors of the PC5. I had to cut the wires before the connector as it was all melted into one piece with the wiring harness main connector.
Could anybody suggest where I could find a couple of new connectors for the PC5 + wiring diagram so that I could put on a couple of new connectors and still use my PC5??
NINJA12
posted July 05, 2009 09:53 AM
maybe you could find a damaged bike harness and get the connectors you need,
BIKELAND > FORUMS > ZX-14.com > Thread: Differences between \'06 \'07 - \'08 \'09 NEW TOPIC NEW POLL POST REPLY
0.29902911186218 seconds processing time
