BIKELAND > FORUMS > ZX-14.com > Thread: Anyone Else See This Stuff? NEW TOPIC NEW POLL POST REPLY
extrapilot
2008 ZX14
posted May 31, 2009 01:23 PM        Edited By: extrapilot on 31 May 2009 21:26
I took these picture from DrewHerc130's post from the Connie forum, but this is the same stuff I'm seeing in the oil and filter after the the first and second oil change @ 2300 mile,
Any ideas what this is from?
TIA.
'pilot
JDC
posted May 31, 2009 02:25 PM        Edited By: JDC on 31 May 2009 22:26
nasty looking.
glad I change my oil at 500, 1000, and every 1500 there after - n - sometimes sooner if it looks like sludge, which seems to be happening since the filter relocation near the ground with the turbo setup.
1badzx12r
posted May 31, 2009 04:09 PM
the way that oil filter is butcher open ..I'd say most of it came from that
extrapilot
2008 ZX14
posted May 31, 2009 04:34 PM
No I don't think so. He stated in the post that he used cutters, the same that I used.
This stuff was in the bottom of the oil drain bucket also. It's metallic what ever it is, attracted to a magnet.
I'm thinking that it maybe coming from the transmission.
'pilot
FasterThanStink
posted May 31, 2009 05:04 PM
This is why we have filters and why we change them often!
That's what gets you.
extrapilot
2008 ZX14
posted May 31, 2009 05:17 PM
Just imagine going by the owners manual that says after the first at 600 miles the next one is 7500 miles, which I can't fathom go that far.
'pilot
posted May 31, 2009 07:43 PM        Edited By: SteveWFL on 1 Jun 2009 03:43
+1
and all we use are magnetic drain plugs in our track bikes for that reason too
extrapilot
2008 ZX14
posted May 31, 2009 08:19 PM
+1
Do you see this kind of material on your drain plug?
'pilot
pissear
Professional Cockis Slap Peer
posted May 31, 2009 08:27 PM
Either the clutch pack is eating itself and did he beat the clutch up on the Connie? That is too large for carbon fluff, unless you can take that black stuff in your fingers and it powders like dry carbon or it is hard like clutch ka-kass?
extrapilot
2008 ZX14
posted May 31, 2009 08:33 PM
I have more of the shinny bright matalic stuff you see in the picture. Is this from the clutch?
'pilot
NINJA12
posted June 01, 2009 12:32 PM
Not unusually to have a little crap in a new engine.
when you change the exhaust, go ahead and pull the oil pan to give it a good cleaning.
while you are in there check the pick up screen.
extrapilot
2008 ZX14
posted June 01, 2009 12:45 PM
I'm going to do a couple of short mileage oil changes with regular Dino oil to help flush the crap out.
'pilot
pissear
posted June 01, 2009 02:55 PM        Edited By: pissear on 1 Jun 2009 22:58
Possibly, Pilot...
That wad in the photo is just break-in. You know how you can see a worn bearing shell and it is shinny [new] on some parts of the bearing and a gray worn area at other places on the shell? I found a piece of what looks like a flake of bearing babbitt. I then tore open the filter. Found diddly squat. And a previous post said that was not from the cutting of the cartridge. I agree. There is a lot of metal spec that could be flattened by the gear mesh and spit out, if not gear chips off the trans dogs or opposite slot on the bang to the next gear.
Either way, as long as there is no noise, no knock in the engine and it is quiet, I would not worry about how much you see there until the next dump of oil and cut into that filter again. I slide a piece of paper under the hot flowing oil coming out of the drain plug; then look for specs of metal.... The carbon is of no concern. Not a thing you can do under combustion and blow-down of these tiny specs you need with a magnifier sometimes.
It is monitoring that crank or rod bearing. Clutch material that is decomposing might be something to ask your Connie friend if he was beating the clutch up? Then there it is. Remove the plate that is deteriorating or burnt. I would still check that bike after a 500 mile run and break the filter open again. It might be a, FBA Connie about to let go.
Some things you find dumping oil:
1. Carbon flake in oil.
2. Bearing material in oil and/or filter ~ Other metal like trans gear flakes that take on a shinny like appearance like insert material. Tiny machined material that was not blown away but pushed against so as not to move or fly out until the oil moved it.
3. Clutch material ~ Gray on the pan is the steel rubbing off the high indent dots of the steel plates. Other material are the burnt pads that cook black then crack off the bonding of the friction plate.
extrapilot
2008 ZX14
posted June 01, 2009 03:33 PM        Edited By: extrapilot on 1 Jun 2009 23:41
Pissear.....What are you referring to in the picture that looks like the "wad" is just break-in stuff.
I don't have quite that much in the filter but it is exactly the same as the shinny stuff.
I thinking also that the gear shift dogs are giving me the shinny stuff in the oil. It is magnetic which eliminates that possibility of Babbitt material.
The trans is a bit notchy shifting, but getting better.
Thanks for the come back, Pissear
'pilot
0.32741212844849 seconds processing time
