BIKELAND > FORUMS > ZX-14.com > Thread: Booza Spring on a ZX-14 NEW TOPIC NEW POLL POST REPLY
Wheelie
Old Man
posted May 20, 2009 03:09 PM
installed the 08 Booza spring on my rear shock, what a difference, stiffened up the soft 14 shock, this will help with a lowered 14 ridden on the street, and will help with to much squating at the drag strip when being launched with a big guy riding, im 217, I would not recommend this for 190lbs and lighter riders, but bigger guys this is perfect, you here that Richcraft? I'll try it at the drag strip Thursday night.
wee
kawasakijockey
posted May 20, 2009 03:29 PM
Good info Wheelie.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
BLK ICE
posted May 20, 2009 04:52 PM        Edited By: BLK ICE on 21 May 2009 00:53
Thanks for the info. I haven't had a problem with the stock shock with 44 tooth sprocket, but my 48 should be here in a day or two and from watching your vid. I think I will need a stiffer shock.
If you know were I can find one plz let me know dhdgr8 at yahoo dot com.
posted May 20, 2009 06:51 PM
I had figured it would be about dead on springrate with 6" stretch and 200-220 lbs rider
Wheelie
Old Man
posted May 20, 2009 06:54 PM
yes I forgot to mention that this should probably be applied to stretched 14's
wee
ZX11D
Internet Police
posted May 20, 2009 08:00 PM
Reading the header, at first thought you will spend this year's spring drinking booze on your ZX-14
Initial impression on a side, thanks for the info
'94 ZX-11
'07 ZX-14
kenneth charles
posted May 20, 2009 08:12 PM
just bought a spring from race tech.looked into the busa spring,i think it has a 13.1kg rating.stock zx is like 9.6kg.recommended spring,for me(240lbs.),was an 11.7kg from racetech.but that is for stock length.brad at racetech ,converted the 11.7 to lbs(x 56=approx 650lbs)added 25lbs to the spring rate for each inch of stretch(6"=150lbs)and came up with an 800lbs(/56=14.28 kg) spring for me.i am waiting on it now,we'll see what happens.just my 2 cents.
spring cost $119
posted May 20, 2009 09:01 PM
I used the stock arm length of 24" + 6" = 30"
30/24 = 125%
125% of what Racetech recommend for your weight on stock arm = xx.xx
this would work in theory for any weight and any length, by determining what rate they recommend stock for your weight, multiplied by percentage of length.
BigJaay1
THUNDAKAT RACING
posted May 21, 2009 07:00 AM
Thanks Wheelie. I will try to get my Busa spring on this weekend.
Jay
2006 Kandy Brandywine / White Diamond ZX14 - HPC POWERED
BigJaay1
THUNDAKAT RACING
posted May 21, 2009 07:07 AM
Jay
joemugg
posted May 31, 2009 06:04 PM
Is the '08 the only one that works, or do the earlier years work also?
'97 GSXR600 street sweeper
Compton
posted May 31, 2009 07:06 PM
08 09 have a heavier spring then the 99 - 07 bikes
b.w.
kenneth charles
posted May 31, 2009 07:28 PM
i installed the '08 usa spring on my 14.the one i had ordered,from racetech,had not arrived when i had the time to change it.rode the bike about 100 miles today,with a 150lb. passenger,without a rub.my bike is 6" over,with soupy's adj. lowering links adjusted out as far as recommended(the length of the threaded body plus 3 1/2")this same set up with stock spring would rub the undertail.i weigh 240lbs.the busa spring has a 13.1kg rating,racetech recommended a 14.25kg for my weight and stretch.the racetech spring arrived on friday,i'm going to try to change it this week.
the14thninja
Show and Go
posted June 01, 2009 01:43 PM
I found my 08 busa spring on ebay for $60 and it works great my 14 has a 240 tire kit and is stretched 8 inches over and it doesn't bottom out when i go 2 up.
I live to ride and ride to live
0.2942841053009 seconds processing time
