BIKELAND > FORUMS > ZX-14.com > Thread: muzzy fuel pump system NEW TOPIC NEW POLL POST REPLY
bigwil
06 zx 14 turbo stage 3
posted May 28, 2009 09:22 AM
just wanted to see if any one else has one on there bike , 699.0 for the fuel system it had less than 200 in parts for 699.00 /189.00 for the fuel rail / buy the way fuel rail did not flow good at all had to go with a billet rail / fuel pump went out in 5 min. called muzzy talked with dave turner he said send it in we will test it , it was bad / they told me the best they could do is sell me one at half price 120.00 what a joke .and i pd for the next day shjping only to get a run around
bigwil// going fast aint easy so turbo it
zxbob
posted May 28, 2009 09:50 AM
I've had bad dealing with Muzzy in the past on defective parts ..... they were no help !
I stopped dealing with them !!
Bob
posted May 28, 2009 01:49 PM
+1
parts missing, they did replace but 3 weeks later than required
Too bad...
MJ
posted May 28, 2009 04:10 PM
Muzzy sucks
davej
posted May 28, 2009 06:47 PM
Muzzy sucks
Crap, always had overboard support.????
Triumph guy
1badzx12r
posted May 28, 2009 07:00 PM
i no buy from muzzy's either ..no way ..
Mark524
posted May 28, 2009 07:34 PM
I've never cared for them but I didn't have too many problems. Made well over 300 hp at stock fp with dry nitrous. Way too expensive for what it was though.
Just wondering how you guys got your fuel gauge to work right with it. I had to put a resistor in line and lost the low fuel warning. They had no idea what I was talking about when I called them.
davej
posted May 28, 2009 07:42 PM
Build your own fuel rail, contact Steve Rice Racing in Pomona Calif, he can solve all your turbo problems.
Triumph guy
posted May 28, 2009 07:43 PM
I thought the sender is seperate from the stock pump.
Whats the level got to do with the additon of the kit?
Please elaborate as I am plumbing my custom system in a few days
Compton
posted May 28, 2009 07:47 PM
The sender is seperate, but when you drop down the pump you'll see a little needle valve. when there is no fuel touching it, it will trigger the low fuel light. You have to put a resistor inline if you get rid of it so your dash wont flash low fuel all the time.
the fuel gauge will only work if you arent low on fuel.
b.w.
posted May 28, 2009 07:50 PM
OK, cool thanks!
will have to check it out,
What size resistor, and what wire?
PS guys , I have comoptons fuel rail.... very nice stuff!
posted May 28, 2009 07:52 PM
http://www.bikeland.org/board/viewthread.php?FID=16&TID=46694&set_time=1240857384
bigwil
posted May 29, 2009 06:17 AM
i have comptons fuel rail it works nice he also has the plate for the bottom of the tank / wish i known that before i got that muzzy crap
posted May 29, 2009 06:27 AM
What size resistor, and what wire to clear the low fuel light guys?
Compton
posted May 29, 2009 09:59 AM
i don't remember i'll have to look this weekend.
b.w.
bigwil
posted May 29, 2009 04:22 PM
there are 3 wires coming from the fueil pump w/ a tester 1 is ground 1 is hot and 1 is low voltige / i just ground the low volt dont no were you would use the resister at inline the wire doesnt go any where now unless he is putting before grounding it
0.26526379585266 seconds processing time
