BIKELAND > FORUMS > ZX-14.com > Thread: smokin, dubious,, question NEW TOPIC NEW POLL POST REPLY
Smooth_G
posted May 21, 2009 08:04 AM
does the stock 14 motors break cam chains??with a shock motor with basic brock mods is it necessary to run a manual cam chain tensioner? what kind of gasket sealer should i use on the valve cover??i got a new gasket n shimmed it, but it still leaks,,the bike is an 08 with 14k,,it runs really good
posted May 21, 2009 12:11 PM
does the stock 14 motors break cam chains??Well not that i have seen.. My 14 with 1200 passes , Jesses 14 with about 1000 passes and with a turbo and spray , Ninja Boys zx14 with 1000+ passes , none of us have had a cam chain go bad ..Unless you build the motor i would forget the manual cam chain adjustor ...
I have yet to have my Valve cover leak on either of my zx14s ..Jesses has a small leak as well as Bigdtd ..I have two new gaskets in stock for them but have yet to get their bikes in the shop to replace them .. If it were me i would use a very light skim coat of hight temp RTV on the flat side of the valve cover gasket , that should do the trick ..Don't use to much because it can be trapped between the gasket and head and cause the gasket to deform or split , Just a very light skim coat is all that is needed..
posted May 21, 2009 12:17 PM        Edited By: SteveWFL on 21 May 2009 20:21
Add my bike to the list of "leaky valve covers" ZX14s paleez
valve cover gasket and snot fixed mine for about 3,000 miles.
Then it happened again and many more fixes were implemented. After a few more times of smelling oil every 3,000 miles and downtime to be fixed I called it quits on the fvckin' bike.
Oil changes every 3K are aggravating enough every 3K, but a fvcked up smelly bike is unacceptable !
posted May 21, 2009 12:19 PM
I had 10,000 HARD miles , average speed on the bike over those 10,000 miles was probably over 100 mph or over 7000 rpm, lots of long distance fast rides.
30 lbs of 50 shot NOS , never had a problem with the tensioner, except a little noise for about 1-5 seconds on start up.
posted May 21, 2009 12:29 PM
Nothing a good tampon would fix ...Every 3000 miles install a new tampon with you oil change ...
posted May 21, 2009 12:31 PM
Steve Posts: 19798 and 19790 postes are about Steves leaky Valve cover gasket ... lol..
ZX11D
Internet Police
posted May 21, 2009 01:27 PM
Aaaah, that's why he sold his 14 and bought that pornstar bike
'94 ZX-11
'07 ZX-14
Smooth_G
posted May 21, 2009 02:41 PM
thanx guys
posted May 21, 2009 03:10 PM
man you know that ain't right
posted May 21, 2009 03:11 PM
actually I sold it the MORNING AFTER returning from the mountains. It was either pour money into suspension stuff or buy a bike that handled.
Also: Honestly I miss the red ZX14 terribly!
posted May 21, 2009 03:12 PM
LOFL
posted May 21, 2009 04:13 PM
LOFL
LMAO! easy you ain't right either, hey how's that oil smell coming off that Kawi? If you park it next to that other leaky one the smell may be different since it'll be in stereo.
bigdtd and smokin'------>
Sticks_n_Stones
posted May 21, 2009 04:48 PM        Edited By: Sticks_n_Stones on 22 May 2009 00:49
What is this mysterious valve cover leak that only East Coast bikes seem to have? None of us West Coast 14's seem to suffer from this phenomenon, and our bikes tend to sit for months at a time when the weather turns to shit. You sure its not just you overreacting Steve?
~cough cough~ overheating west coast 14's ~cough cough~
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
posted May 21, 2009 05:11 PM
Me over reacting??????? Two more leaky ZX14s were mentioned in this very thread. And west coast hasn't had that prob? Search the forum you'll find different
I'm trying to fight my way out of this corner I'm not even supposed to be in!
posted May 21, 2009 05:25 PM
1badzx12r
posted May 21, 2009 05:32 PM
really made an improvement buying a yamahahahahaha..
posted May 21, 2009 05:41 PM        Edited By: SteveWFL on 22 May 2009 01:45
yes sir, and actually the 600RR handles better than the Yamaha
and neither leaks
One day I'll have another 14
1badzx12r
posted May 21, 2009 05:53 PM
and neither leaks
but its been a long time since either brand won any races ..
posted May 21, 2009 07:25 PM
"either brand won any races
1bad....LMFAO
maybe "drag" races (correct), but the rest of the planet and most of America doesn't go straight
Sticks_n_Stones
posted May 22, 2009 05:33 AM
Hmm. Where do I start with that so-very-quotable statement? Does explain all those hot chicks that seem to hang around you, you're "safe".
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
posted May 22, 2009 05:35 AM
believe that with all your heart too
rich s
posted May 22, 2009 09:14 AM
If you can't beat them join them...then beat them, they will let you
Sticks_n_Stones
posted May 22, 2009 10:06 AM
sick rich, you're definitely sick... Though I had a girlfriend who was into that once. And she had a girlfriend that was into the both of us AND into S&M also. Damn I miss my single Navy days.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
TampaSmitty
posted May 22, 2009 10:28 PM
my 04/06 leaked like a stuck hog. damn thing. thats the reason i traded it for a harley , went from one leaker to another lol.
actually my harley nevere leaked till i thought i was on my 14 when i went into a curve way to hot and it started dragin everything till it came out from under me.
but i rode the snot out of that 14 everyday at 100+ and even with the leak and the rattle battle from the cam chain. it still fired up every day and handed ATL street squid there a$$es. im gona give this 07 a punch in the balls if it spews oil on me darnit.
actually the frame says 12/06 i might be in for it.
06 1st gen zx14,muzzy full exhaust, pc3,no flies tuned at 180rwhp and sold after 15500miles with leaky valve cover bolts and a shreaded back tire.
now 07 ,corbin hardbags
pc3, muzzy m14 ,flies out..
posted May 23, 2009 09:03 AM
"my 04/06 leaked like a stuck hog. damn thing. thats the reason i traded it for a harley "
WOW, I thought I was pissed off about the leaky junkbike being in the shop so many times for warranty crap, but i didn't go to those extremes
0.27173209190369 seconds processing time
