BIKELAND > FORUMS > ZX-14.com > Thread: Tiger Tail vs. Removing fender NEW TOPIC NEW POLL POST REPLY
14nooby
posted May 16, 2009 10:32 AM
First off I weigh 150 lbs. I adjusted my shock to the stiffest setting. I cut out my fender and riveted a piece of sheet metal up there which gave me 1 inch more of clearance. I still rub. I know that heavier riders would rub but I can't believe that I rub. How much clearance does the tiger tail give you?
posted May 16, 2009 10:43 AM        Edited By: dubious on 16 May 2009 18:44
approx 1" more as i recall.
It will run tight to the bottom of the subframe tubes if you wan to measure or check and be sure,
Wheelie
Old Man
posted May 16, 2009 11:26 AM
my tigertail rubs, shock tight as it will go, settings maxed, just got a 08 Booza shock "spring" from Shankrr, will try it next week. 217lbs. and 63"
wee
0.2609851360321 seconds processing time
