BIKELAND > FORUMS > ZX-14.com > Thread: Oil coming out crank breather 08 turbo 14? NEW TOPIC NEW POLL POST REPLY
duncan
posted March 30, 2009 03:52 AM
Buddy of mine called me and said his bike is letting go of some oil when under boost through his crank breather. Enough that it coats his tail section somewhat. Off boost nothing, and bike pulls and rides fine...OK TURBO DUDES TAKE A STAB AT THIS, MY FRIEND IS AFFRAID TO RIDE ANY MORE AND I DON'T BLAME HIM.
posted March 30, 2009 03:57 AM
Our Turbo Busa will puke some oil if it is even slightly overfilled.
posted March 30, 2009 05:06 AM
time for a leak down....
pissear
Professional Cockis Slap Peer
posted March 30, 2009 07:19 AM
Remove the breather tube (found on left side, near the rear frame/engine rail support). I use a catch tank like old style. The blades will spool the bike where the crankcase is closed loop to the ram chamber. You might ratiout; where oil will detonate or your oil to gas ratio is low enough like a 2-Stroke, that it will live and not detonate with excessive oil burning.
Here is you normal N/Assliding the cable rip. Not much to speak about having any det going on. That is very little oil entering if you are the walkaboutype, WOTTing the tarmac = N/A.
<< Dual open breather tubes is no catch tank is catch air.
0.23199701309204 seconds processing time
