BIKELAND > FORUMS > ZX-14.com > Thread: Sparkplugs for nitrous NEW TOPIC NEW POLL POST REPLY
Douglas Home
posted March 27, 2009 02:46 AM
Hi last question on my new setup , Im putting on a dry 40 shot and a hub and will get a dynod second map for the nitrous , Im spraying in the ram air before the filter . What plugs are best?? Im leaving the timing stock . I just had a box delivered from Schnitz , and this weekend will be installing a puig DB , PMR tether killswitch , Brocks clutch springs , sliders and stand spools , hub , extra fusebox , schnitz air filter cover. , Dynotune window switch ,and bottles , etc . While Im at it I will check out the tip over sensor I hear you guys on about.! This will complete my project except for those BST rims that my wife says are at least a year away . Thanks again for all the help over the last month , It has made choosing the right parts a lot easier . I will post some pics of the blackest 14 when its all done.
Doug Mackay Australia
Douglas Home
posted March 27, 2009 06:10 AM
Help CR10EK or CR9E1A-9 or ?????
posted March 27, 2009 07:39 AM
Many prefer the larger dual strap electrode of the CR10ek, and I definately would run the cooler #10 plug of either series either way.
Tighten the gap to .020 ~.025 to prevent flame out.
Your cylinder pressure increases dramatically with nitrous and increases resistance to arc across the plug.
posted March 27, 2009 07:47 AM
cr10ek or cr10eix
woppi
posted March 27, 2009 09:43 AM
NGK CR10EK
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
posted March 27, 2009 10:02 AM
my fave...
Douglas Home
posted March 28, 2009 02:47 AM
Thanks again Dubious , got hold of those plugs today. Was a busy one , installed my bottle / solenoid / window switch / new fuse box / speedo healer and started on the hub .Another question as Im new to doing my own work , The pressure input harness supplied with the hub kit is for turbo only ? so does that mean just dont connect it to anything ??? Also is the supplied map selection switch waterproof ? Same with the speedohealer remote button , is that one waterproof? If they arent I think I will swap them out . I am an obsesive / compulsive silicone and waterproof type of guy.
posted March 28, 2009 07:35 AM        Edited By: dubious on 28 Mar 2009 15:36
I never used the pressure input harness on nitrous. It is for turbo.
The switch and speedohealer are water resistant I beleive.
I used to bag my lcd or removed it when hitting the bike with pressure washer, but never had any issues when riding it home in mild rain conditions.
Never had any problems with any of it.
Douglas Home
posted March 28, 2009 10:17 AM
Thanks again/again/again Dubious , If your ever heading my way let me know , asI owe you a favour .
posted March 28, 2009 02:31 PM
I would love to come and visit!
My wife would love it too...she's been bugging me to travel... LOL
Douglas Home
posted March 28, 2009 05:33 PM
Spare room here for you both any time , its a great place , except for our unprepped wheel spinning track but we still have fun.
Stu64
posted March 29, 2009 10:55 AM
Plugs too rich?
I bought a set of CR10EK's yesterday after reading this thread. I have a 50 dry system that i want to use for T&T (its to much for the 950 class).
Question is will these plugs be to cold for running without spray? Took the old plugs out today and they look awful rich already,opinions?.
bike sees only track use no street use so its at WOT most of the time.
posted March 29, 2009 02:22 PM
The porcelin looks not bad.
Are you running pump fuel?
When the porcelin looks clean and the the rest of the plug looks dirty, allot of the time its due to dirty fuel (pump gas)
How many miles, what map, what afr?
I tried using Brocks Maxton map, and his pump gas track map, but went to his street map and it cleaned things up.
Are you using a second map for Nitrous, have you tuned both on the dyno or run AFR?
Stu64
posted March 29, 2009 03:53 PM
Pump fuel,this was dyno mapped for the Tsukigi exhaust.
I bought a used Brocks sidewinder that i will be running this year,so once i get it all together i will try one of his maps.
I would like to get it to the dyno again for a nitrous map too. I have the LCD and hub so i can switch maps(think i bought it from you?) Stu.
Douglas Home
posted March 30, 2009 12:39 AM
Dubiuos , I set the CR10EK plugs to .020 / .025 as you recomended for my dry 40 shot , if Im just street riding on pump fuel , are they OK to leave in??? Thanks again ,sick of my lack of knowledge yet ? Doug
posted March 30, 2009 05:10 AM
Yes , fine to run.
I ran mine 7000 miles at a time.
Pump fuel leaves alot of carbon on the plugs sometimes as STU is seeing.
(looks a bit rich too)
Douglas Home
posted March 30, 2009 10:10 AM
Thanks again , couldnt have got this far without your help!
0.24973917007446 seconds processing time
