Douglas Home
posted March 11, 2009 12:43 AM
raptor shift/launch light
Has anyone wired up one of these? Ive got the green wire that says to connect to the vehicle speed signal (vss) output from the ECU. I cant find this in the manual,can I use the speed sensor signal from the front sprocket cover or pin 13 at the back of the instrument panel ? I must give these guys a recomendation as they sent a second unit after UPS lost my parcel and were great to deal with!!! Thanks for any advice, Doug Queensland Australia
Doug Mackay Australia
06redzx14
posted March 11, 2009 05:08 AM
connect the green wire to the negative side of the number 1 coil. set the cylinder mode to two and set your shift point to half the desired value
Douglas Home
posted March 11, 2009 10:21 AM
Thanks Red ,but I think that is for the raptor shift light ,this unit also has launch mode and four wires , help, got busas to bash on friday night!!! thanks Doug Queensland Australia.
06redzx14
posted March 11, 2009 11:07 AM
not sure exactly which wire it is, but have you checked the 3 wires that come from the front sprocket cover?
pazx14rider
posted March 11, 2009 01:44 PM
quote: Has anyone wired up one of these? Ive got the green wire that says to connect to the vehicle speed signal (vss) output from the ECU. I cant find this in the manual,can I use the speed sensor signal from the front sprocket cover or pin 13 at the back of the instrument panel ? I must give these guys a recomendation as they sent a second unit after UPS lost my parcel and were great to deal with!!! Thanks for any advice, Doug Queensland Australia
I dont understand why they would be wanting you to hook into the speed sensor for a launch or shift light. I hooked my MSD launch and MSD shift light,. Launch controller had its own harness that plugged inline with each individual coil. And The Shift light picked up a tack signal off of coil #1 for rpm signal, i beleive it was white with a red tracer.
Douglas Home
posted March 11, 2009 09:54 PM
Well this thing is still not working, Ive now connected this wire to the blue/yellow stripe at the plug for the countershaft speed sensor signal. I then fully programed the shift/launch light ,this went well . However the light does not work in either function. Help ,racing tommorow night Thanks Doug Queensland Australia.
Douglas Home
posted March 12, 2009 12:58 AM
ready to bash busas now . for future reference to help others black to ground/ red to switched fused active / white to coil one( red with white stripe) and white to speed sensor plug (blue/yellow stripe) on front sprocket cover. Now for the important bit ,when going through the programing steps ,set it for one cylinder ,not four . Well that is what worked for me!! It seems like agood product , mines black with blue leds ,its very compact and bloody bright !!! Doug Queensland Australia
WindSwordNinja
posted March 12, 2009 08:14 AM
Have fun bashing those Busa's!
Post a pic of the shift light on your bike if you can.
2014 ZX14 Black and Green
2008 ZX14 Black and Red SE
1986 ZX1000R Black
"Faster, faster! Faster would be better!" (Serenity)
