BIKELAND > FORUMS > ZX-14.com > Thread: new found respect NEW TOPIC NEW POLL POST REPLY
Bawls
re-learning to ride
posted February 17, 2009 12:50 AM
new found respect
I have a new found respect for those of you who have installed exhaust lol. Talk about a royal pain in my dick lol. I didn't have the long extension or swivel, so i'm sure that that made things a little more difficult, but it took damn near 3 hours from start to finish. I ended up putting the smeg on for now, but will end up with the shorty gen3 can on after I take it to the track. I must say that I'm happy with how everything fit and I'm glad that I knew to use a shoestring to pull springs with because trying to do it with the supplied wire puller would have been next to impossible. I'll get some pics up soon.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
posted February 17, 2009 04:13 AM
After you do it 10 times or more, it's easy.
LAB3
posted February 17, 2009 04:18 AM
I am looking at Brocks exhaust. I see how some are selling a smeg for the Allien head, etc.
I was looking at the gen3 with a standard can like most sport bike systems. I do not drag race much anymore. I am looking for more HP but do not want to loose the low end torque from 3to5 K . Which system? Does all of Brocks have the same head pipes.sidewinder excluded..:-) been there with a V&H on a 1980 GS1100 back in the day.
Shoestring on springs?
Louis
Compton
posted February 17, 2009 04:26 AM
exhaust was easy.
after a while you can start dropping the engine/trans in a 14 with the already plastics off in 20 or so mins.
b.w.
pazx14rider
posted February 17, 2009 05:33 AM
and just a side note let the RTV set up before starting the bike or you will have RTV all over your garage wall!! lol
BobC
posted February 17, 2009 05:37 AM
Did you remove the horn and the lower radiator mounting bolts? Takes a couple of minutes and with the bottom of the rad' swung out an inch or two it's a lot easier to get to those header nuts.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
posted February 17, 2009 06:23 AM
LOL,
how much did you use bro? LOL
all it needs is a little skim on the mid pipe, the pipes are slip fit
Bawls
re-learning to ride
posted February 17, 2009 07:48 AM
i ended up lossening the rad and swinging it forward after about 3 beers and 2500 curse words.
the shoestring trick is as follows...
1. tie a bowline knot or any knot that will allow you to have a loop on the end of your string that doesn't slide.
2. place the loop where you would use the string puller.
3. pull the spring into place.
4. untie the knot leaving your string the way it was before you started.
5. pull the string out from under the exhaust spring.
6. repeat on all other springs.
this will allow you to have more leverage by using a long string. hope it helps you guys. that's a trick that i learned working on yamaha banshees back in the day.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
LAB3
posted February 17, 2009 07:59 AM
Thanks, good idea.
BobC
posted February 17, 2009 08:09 AM
I know this is worth zilch at midnight when the store is shut but a proper spring hook is really cheap and would be a good addition to any biker's toolbox. I use mine for the sidestand springs as well as the exhaust.
Stock wheelbase
Bawls
re-learning to ride
posted February 17, 2009 08:33 AM
try the string... guaranteed it works better than any spring puller. I use 550 chord, and it works like a charm.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
zixxer14
Damn that was Quick
posted February 17, 2009 01:54 PM
Try safety wire & vise grips, make a loop, clamp it in visegrips, pull spring into place, release wire & pull out, repeat as necessary. You can make it any length you need & generally reuse wire many times. Cheap too!
posted February 17, 2009 02:13 PM        Edited By: SteveWFL on 17 Feb 2009 22:18
+1
I've even used safety wire in place of my springs on my track bike exhausts when in a pinch.
tnt
posted February 17, 2009 03:47 PM
Neccessity is the mother of invention! I got plenty of string( and spring pullers) ,now all I need is a new pipe!!! Where's them pics?
Rook
posted February 17, 2009 06:38 PM        Edited By: Rook on 18 Feb 2009 02:40
You're not alone, Bawls. Everything takes me at least three hours the first time I do it. Adjusting my chain was a big job the first time. I totally believe paying close attention and being careful with your own bike work pays off. Even if I could afford to have a shop do it, I wouldn't feel the satisfaction of knowing what's going on with my bike. I believe doing your own work builds a closer conection to the bike and vastly improves decision making when riding. I never encourage anyone to bring there bike work to a proffessional unless they truely hate doing mechanical work or if they feel the job is a super high safety priority that they don't feel comfortable trusting their own skills to (installing tires might be one of those jobs).
It is amazing how much you can do without any special tools. A set of sockets and 4 hex keys will get just about everything you need done.......and a shop manual.
Rook
posted February 17, 2009 09:58 PM
I allways just pull the rad now. more work but easier work
BobC
posted February 18, 2009 04:09 AM        Edited By: BobC on 18 Feb 2009 12:51
Like all the best tools it's simple and effective........and I still have skin on my knuckles
Stock wheelbase
BIG BLUE_ZX14
posted February 18, 2009 09:14 AM
LOL,
Please excuse the ignorant question...is the RTV a different sealant than the Ultra Copper that Brock's installation instructions mention? Further, he does not mention putting any sealant on the mid pipe, only up by the header inlets. Please advise.
2007 Blue ZX14 Gone...
mike1024
posted February 18, 2009 10:15 AM
I hated installing brocks pipe, cause I didnt use a swivel tool, until 30m before I finished!
If you have the tools, and a brain, and think before you act, installation is a breeze!
It took me 10hrs from 2pm to midnight getting it in and done perfectly the first time.
mapped it 10 miles later, and that thing is a certified beast!
GO BROCKS! Excellent pipe!
BIG BLUE_ZX14
posted February 26, 2009 01:17 PM
I know this is old news to everyone but Holy Shite are the stock cans HEAVY. It warmed up enough to start installing my Gen 3 system. I think one stock can weighs more than the entire Brocks system.
0.24634194374084 seconds processing time
