BIKELAND > FORUMS > ZX-14.com > Thread: on board air compressor NEW TOPIC NEW POLL POST REPLY
jdrill04
posted January 19, 2009 04:22 PM
I have the muzzy air shifter, but i am wonting to run a onboard air compressor. what all would i have to change out? I would think i could use the digikill box and shift cyc. I just don't know about the rest.
pazx14rider
posted January 19, 2009 05:13 PM
go back on or 2 pages on the posts there was just a thread on that very subject.
jdrill04
posted January 19, 2009 09:41 PM
ok thanks
1badvespa1400cc
power junkie
posted January 20, 2009 09:32 AM
+1(LOL)
Just another foeteen!!!!!
jdrill04
posted January 20, 2009 01:31 PM
i read the reply on the onboard compressor , but it doesn't mention anything about using digikil box. it also says he was using mps kill box. mps isn't high psi shifter, the muzzy one is. i wasn't asking how to install i was asking would i need to change out the hole system to install a compressor. thanks
kawasakijockey
posted January 20, 2009 01:48 PM
No, just remove the high pressure regulator. Everything else hooks up the same. Just install the compressor inline of the hose coming off the bottle.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
jdrill04
posted January 20, 2009 01:58 PM
very much appeciated!
1badvespa1400cc
power junkie
posted January 20, 2009 02:54 PM
I run the mps setup at 200psi and never had a problem.What do you mean by high psi shifter?
kawasakijockey
posted January 20, 2009 03:43 PM
The Muzzy kit works off of CO2, Nitrogen, or Nitrous Oxide which has a pressure of about 900+psi so it needs the regulator to bring the pressure down to 150psi or less.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
1badvespa1400cc
power junkie
posted January 20, 2009 05:41 PM
Gotcha,thanks.
0.21528887748718 seconds processing time
