BIKELAND > FORUMS > ZX-14.com > Thread: Buell Peg Mod Info? NEW TOPIC NEW POLL POST REPLY
posted January 20, 2009 07:59 AM        Edited By: Shane661 on 20 Jan 2009 16:00
Buell Peg Mod Info?
I have a set of Buell pegs. They look to be about .10 too wide to fit in the factory slot. In addition, the hole for the pin needs enlarged. I also noticed they have a gusseted area, and I am not certain if that will need removed.
There was a link for a document that detailed the mods needed, but that link is no longer working. Can anyone point me in the right direction? I'd like to find out the full details of the swap. Thanks.
KSPZ3
posted January 20, 2009 10:05 AM
Shane - BTW - I found the Buell Peg set-up problematic for LSR - Aerodynamically. The notch in the pegs prevented the ability to pull your foot in tight.... I switched back to stock - and eventually installed regular adjustable racing pegs.
Kevin
KSPZ3
posted January 20, 2009 10:11 AM
BTW - If you are interested I could look for mine - and if I find them you are welcome to them already ground and ready to go.
posted January 20, 2009 10:50 AM
That's a good tip on the pegs splaying your feet out. I didn't think of that.
Did you use rearsets? What type of pegs? I am looking to go a little lower and back on the pegs. I was thinking of rearsets, but then I would have modify my airshifter setup.
MasterBlaster
posted January 20, 2009 12:19 PM
What tey look like installed. Not a problem for me, but my shifter is offset out a little also. I find them perfect for me.
A different model on my Concours. I like them also
KSPZ3
posted January 20, 2009 07:19 PM
Shane - yes - I have the rearsets - I will take a look and get the brand - I bought for the same reason - I will get some pictures for you. The problem that I was trying to solve was getting my elbows and feet in for better aero. I think we are both about the same size. mufflers are a problem - Brock set up. I melted two sets of boots at Bonneville - five mile flat out and the exhaust gets a bit hot.
Kevin
WindSwordNinja
posted January 20, 2009 07:19 PM        Edited By: WindSwordNinja on 21 Jan 2009 03:21
Shane, here is a link to a good "how to" write up on a different site.
I used it to install mine and it was easy to follow.
http://www.zx14.info/forums/viewtopic.php?f=19&t=5&sid=2f621095725d241d86438547e4f7c36b
2014 ZX14 Black and Green
2008 ZX14 Black and Red SE
1986 ZX1000R Black
"Faster, faster! Faster would be better!" (Serenity)
0.48185181617737 seconds processing time
