BIKELAND > FORUMS > ZX-14.com > Thread: More 09 testing ............. NEW TOPIC NEW POLL POST REPLY
posted January 09, 2009 08:40 AM        Edited By: smokinZX14 on 9 Jan 2009 16:45
As most of you allready know i made a few passes on my 09 zx14 a while back and ran some mid 6.20s @ 118 with the stock exhaust .. 1/4 miles time of 9.62 ..
We had a 3 week down time because of Xmas and new years so i'm a little rusty ...Fast forward to Dec 7th ... My best 60 foot time was 1.59 but i blew that run with a wheely and put down a 6.18 @ 119.99 .. Later i put down a 6.15 @ 120. 40 with a crappy 1.61 60 footer .. It's hard for me to go from 64 inch wheel base of my 06 zx14 to the 57 1/2 inch wheel base of my 09 zx14 , it takes me a few test and tunes days to get my 60s back down to 1.50s that i have run in the past ...
I knew my 60s would be off so i wasn't looking for great ETs but i was looking for a increase in MPH ... All stock my best was 118 and with Brocks Smeg installed off my 06 the MPH jumped to 120.40 .. So i got what i was looking for with a jump of allmost 2 1/2 mph with just a pipe change ...Remember that is without a P/C , i just bolted the pipe on and made NO other changes ... Next week i'm going to swap out my stock air filter out with my BMC filter in my 06 zx14 and see what i pick up with that single change ..After i get some numbers with the air filter swap i will add a P/C and a Brocks street map ...Later testing will include pulling the flys and a flys out race map from Brock ...
Stay tunned ...Smokin ..
posted January 09, 2009 08:45 AM
It's like starting over again right Lee
posted January 09, 2009 08:50 AM
Yes it is Rick .. But it's a hole lot off fun !!!!! I want to map each change one at a time because i really didn't do that with the 06 ..The 06 got 2 or 3 changes at a time so it was hard to tell what each mod gained ...
posted January 09, 2009 09:44 AM
Excellent...
Im all for going fast with the least amount of mods!!!
Especially in today's economy, one can go fast with very little mods!!!
1badvespa1400cc
power junkie
posted January 09, 2009 09:47 AM
Smokins the man!!!!!!
Just another foeteen!!!!!
gilberjj
Friend of Fast
posted January 09, 2009 10:46 AM
nice.... thanks for the free research.
posted January 09, 2009 11:06 AM
Watch out Lee, there may be a V-Max looking for you...
posted January 09, 2009 12:34 PM
Bring them Vmaxs on !!!!!! It's getting old waiting and waiting and waiting some more .. lol...
Bawls
re-learning to ride
posted January 09, 2009 02:27 PM
i'll be testing the 16t front sprocket tomorrow . It's been a few weeks since I went to the track last and I'm feening for it lol.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
pazx14rider
posted January 09, 2009 02:45 PM
Grrrr seven inches of snow here tomorrow you guys suck!!
Bawls
re-learning to ride
posted January 09, 2009 03:00 PM
I'm pissed right now. it's been cold in san diego (40's and 50's) for the past 3 weeks... low and behold the santa anna's are supposed to blow in tonight lol.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
posted January 09, 2009 03:02 PM
Thanks , you just reminded me that i need to order a 16 tooth .....Bawls make sure to post up your numbers with the 16 tooth sprocket ..
16 tooth worked well on my 06 at stock wheel base so i need to test that on the 09 ...
duncan
posted January 09, 2009 04:53 PM
Smokin have you ever considered boring your throttle bodies? I've been told by some good engine builders you will add 3-5 ponies in the top of your rpms. Lee Sheirts did this on my 1397 busa a few years back and swears by it.
rACeRs
posted January 09, 2009 05:56 PM
Nice times. I look forward to seeing if the 16t front helps.
9.1 @ 149 w/ 1.57 60' SWB
posted January 09, 2009 07:54 PM
its great that you are doing it incrementally. that should tell us what gives you the biggest bang for the buck. of course the brocks pipe woke it up. it will be interesting to see what an air filter and maybe some mapping will do. that bike is sharp, and runs strong.
Bawls
re-learning to ride
posted January 09, 2009 08:31 PM
I would personally llike to tell smokin to quit complaining about 1.61 60ft times lol. I understand that it seems horrible compared to the 1.35's that your used to but when you complain about a 1.6 it makes me feel like a complete retard lol .
oh wait... never mind I am... but still, it's not nice to rub it in
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Bently
2012 14r In Blue and no Mods!
posted January 09, 2009 09:13 PM
I'm to curious to see what a pwr commander and map will do, because by what I have seen on the 08 busa it isn't much.
posted January 09, 2009 09:30 PM        Edited By: smokinZX14 on 10 Jan 2009 05:33
Bently i'm thinking the same thing ... Not sure if the 09 zx14 is as rich as the 08 zx14 on the top end ....If the 09 is as fat in the upper RPMs a pipe and air filter should over come that , at least thats what i'm thinking .. I see no problem leaving the flys in at this point so no real need for low and mid range mapping ..But it is possible that even with the pipe and filter it still maybe rich on the top end and could pick up a few ponys ..I'll have to give Brock a call and see if he has put a 09 on the dyno and see what the fuel ratio looks like .. We know the 07s and 06s were fat up top and Brocks maps pull some fuel out in the upper RPMs ...Could be the same for the 09 and possible worse than the 07 06 zx14s ..
Right now the bike has more low end and mid range than i can use at stock wheel base so i see no real hurry to remove the flys ..That could change if the bike was at 62 or 64 inches of wheel base ..But i have no plans to make it longer because i allready have one like that ..
Also keep in mind this bike has only 350 miles on the clock and we all know they really don't start running strong till they get about a 1000 miles on them ..
smokin..
Ninja14
posted January 09, 2009 10:35 PM
Hey Lee...
This one is waitin' for ya'
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
KillaKAW4LIFE
posted January 09, 2009 11:58 PM
Hey Smokin, What happen to your ZX10 Testing. Haven't heard anything in a while.
bawls
re-learning to ride
posted January 10, 2009 06:16 AM
he gave his 10 to me and promised not to ride it anymore until I had the chance to come pick it up... such a gererous man that smokin' is
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
posted January 10, 2009 06:22 AM
Hey Lee...
Badass!
posted January 10, 2009 09:26 AM
Hey Lee...
Badass!
Man that was bad ass ...cool.....
posted January 10, 2009 09:31 AM
I picked up a 16 tooth sprocket today and it is installed and ready for next test and tune ...I'll test the air filter the following week ..
Five things i like about a 16 tooth
Easier on the clutch
Better 60 footers
Moves the axle back a bit for much needed wheel base
Cheap mod with a big bang for the bucks
Much stronger roll ons ...
0.2792661190033 seconds processing time
