BIKELAND > FORUMS > ZX-14.com > Thread: lowering my zx-14...and stretching it... NEW TOPIC NEW POLL POST REPLY
CUSTOM ZX-14
posted January 08, 2009 07:28 PM        Edited By: CUSTOM ZX-14 on 9 Jan 2009 03:56
What are good lowering dogbones? and what do yall think about bolt on stretches? and a place to start looking?
07 custom zx-14
01 GMC DURAMAX 790 r/w hp
Bawls
re-learning to ride
posted January 08, 2009 07:37 PM
i'm running the muzzy 3-hole links on the second hole, but any of the 3-hole links will work. I would say that whatever your budget will allow will be your best bet. if you're broke like me... 3-hole links. if you've got the money... brocks adjustable links.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
CUSTOM ZX-14
posted January 08, 2009 07:53 PM
idk maybe its just me but I dont see how adjustable links are safe...
07 custom zx-14
posted January 08, 2009 08:11 PM        Edited By: dubious on 9 Jan 2009 04:15
I have ran threaded links for over 10,000 miles, no problems!
If you install them right and make sure there is a 1/2 " of thread in each end( not over extended) then they are totally safe.
There are cheaper alternatives than Brocks, so you can do it right , but alot less money.
Brocks are the fanciest, easiest to adjust, but not necessary to have complete adjustability.
The great thing about threaded adjusters is you can adjust them without disconnecting or suspending the back half of the bike.
In fact I would feel confident to say the adjustable links are far safer than swingarm extensions... but thats another topic...
Anyway tthe threaded link have locknuts and will not loosed when locked properly, wheras swingarm extensions require regular scheduled prudent inspection, and tightening.
Good luck!
ninjaboy311
posted January 08, 2009 10:25 PM
I've drag raced over 900 passes with my Naarden adjustable links with no issues at all.
posted January 08, 2009 11:28 PM
i ran my extensions for 2 seasone with no regular tightening. they were as tight the day i took them off as the day i put them on. not all extensions are created equal
1badvespa1400cc
power junkie
posted January 09, 2009 06:36 AM
I run the soupys adjustable links,there made out of stainless steel and work great!!!
Just another foeteen!!!!!
soupy
posted January 09, 2009 11:21 AM
How do u subscribe to a thread without replying? This was the only way I could see to do it.
  Ignore this member    Click here to visit soupy's homepage.
kawasakijockey
posted January 09, 2009 12:13 PM
Soupys are on mine too.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
1badvespa1400cc
power junkie
posted January 09, 2009 02:10 PM
Ive had his links on all of my bikes and never had problem plus he ships them fast.
pazx14rider
posted January 09, 2009 02:49 PM
I just got the Brocks pin style adjustable lowing links, Quite salty at $300 bucks, but crack 2 allen head bolts loose on each link have someone grab the tail and pick slammed, middle, or stock, pull the pins and set where you want then tighten your allen head bolts back up!
0.22849297523499 seconds processing time
