BIKELAND > FORUMS > ZX-14.com > Thread: AIR SHIFTER KILL BOX NEW TOPIC NEW POLL POST REPLY
1badvespa1400cc
power junkie
posted December 17, 2008 06:10 AM
IS THERE ANY WIRES NEAR THE REAR SEAT AREA TO WIRE THIS OTHER THAN GOING ALL THE WAY TO THE FRONT TO THE COILS,I WANT TO MOUNT THE BOX UNDER THE REAR SEAT AND NOT HAVE TO RUN THE WIRES ALL THE WAY UP.
Just another foeteen!!!!!
kawasakijockey
posted December 17, 2008 06:38 AM
If you have the kill box for the coils you could scotchlock the wires at the ecu. You will need the wiring diagram to find them. They are w/r (#1Coil), w/bl (#2), w/g (#3), w/y (#4). They should be near each other on one section of the ecu harness.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
1badvespa1400cc
power junkie
posted December 17, 2008 06:59 AM
SWEET APPRECIATE THE HELP,SO IF I FIND THOSE WIRES AT THE ECU JUST TAP INTO THOSE WIRES AND THAT SHUOLD BE IT?
kawasakijockey
posted December 17, 2008 07:06 AM
You have the mps ?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
1badvespa1400cc
power junkie
posted December 17, 2008 08:48 AM
Yes I do,why?
kawasakijockey
posted December 17, 2008 11:09 AM
Because the MPS lets you tap the 4 brown wires right to the 4 mentioned coil wires. The red wire for the MPS can also be tapped onto the red single wire that feeds all 4 coils.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
1badvespa1400cc
power junkie
posted December 18, 2008 07:06 AM
Thank's for the info!!!!!
kawasakijockey
posted December 18, 2008 08:13 AM
No problem.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
1badvespa1400cc
power junkie
posted December 30, 2008 06:54 PM
any pics would be appreciated
bawls
re-learning to ride
posted December 30, 2008 06:58 PM
+1
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
1badvespa1400cc
power junkie
posted December 30, 2008 07:37 PM
Also where can I get a switched power source for the mps box back by the ecu.
06redzx14
posted December 30, 2008 07:52 PM
i used the tail light wires
kawasakijockey
posted December 30, 2008 09:02 PM
I dont have pics because I use the Digikill.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
1badvespa1400cc
power junkie
posted January 01, 2009 08:28 AM
I have the color for the wires that I need to use but I cant find them by the ecu,there are two plugs that go into the ecu,is it the wide or narrow plug that I need to look for the wires in?
kawasakijockey
posted January 01, 2009 09:42 AM
It should be the plug with a total of 19 wires.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
1badvespa1400cc
power junkie
posted January 01, 2009 03:20 PM
Every plug that I count has less or more,this sucks,all I have to do is wire this up and im done.
kawasakijockey
posted January 01, 2009 04:39 PM
It should be the one of two at the ecu that has the least amount of wires. I counted 19 in the wiring diagram.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
kawasakijockey
posted January 01, 2009 04:58 PM
Man, I apoligize. I told you that ECU plug has 19 wires. WRONG, it has 17 wires on the drawing. I hope you figure it out.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
1badvespa1400cc
power junkie
posted January 02, 2009 05:56 AM
1badvespa1400cc
power junkie
posted January 02, 2009 09:21 AM
Is it okay to hook to the wire down by the horn,instead of tapping into the harness by the switch?
1badvespa1400cc
power junkie
posted January 02, 2009 09:22 AM
For the button,sorry.
06redzx14
posted January 02, 2009 09:23 AM
works just the same either way
kawasakijockey
posted January 02, 2009 11:01 AM
When I installed these things I would pull the wire from the horn itself that comes from the horn button and run it to the "common" on the 2 position selector switch and then run from one of the 2 contacts on the switch back to the horn and the other contact to the killbox. All of this to avoid cutting/splicing wires which is a big pet peave of mine.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
1badvespa1400cc
power junkie
posted January 02, 2009 11:46 AM
Which two position switch are you refering to?
kawasakijockey
posted January 02, 2009 12:20 PM
The switch that lets you select between shifter or horn.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
0.23532199859619 seconds processing time
