BIKELAND > FORUMS > ZX-14.com > Thread: Anyone here using a aluminum rear sprocket? NEW TOPIC NEW POLL POST REPLY
rACeRs
posted December 15, 2008 12:07 PM
Im trying to get a 40t rear sprocket and i have found a local shop that has one in stock, but it is aluminum. And Im just wondering if it will be ok. I know that aluminum wont last as long as a steal unit. I just dont want to put in on and have it strip all the teeth off and end up damaging the bike and possibly myself.
The one I found is a sprocket specialist ultralite. I called them and they said that the ultralite option saves weight, but doesnt sacrifice any strength? Dont know about that one, but they said it will match the strength of the stock unit, I hope so.
9.1 @ 149 w/ 1.57 60' SWB
posted December 15, 2008 12:08 PM        Edited By: Shane661 on 15 Dec 2008 20:08
Yes, it will be ok. I have run the Vortex and Renthal at the dragstrip, and the Renthal at Maxton as well.
rACeRs
posted December 15, 2008 12:16 PM
Right on, thanks for the fast reply Shane. Im headed out the door then
Tool Man
posted December 15, 2008 12:21 PM
I run a alum. Renthal 43 rear. Be good about cleaning and lube. I can get about 10,000 out of a set.
The banks are failing..
The banks are failing...
Invest in Ammo
rACeRs
posted December 15, 2008 12:48 PM
Good to hear. Thanks for putting my nerves at ease
duncan
posted December 15, 2008 02:42 PM
It will be fine, I run an aluminum on my turbo bike[428hp] no problems, but it's not as strong as the stock one.
posted December 15, 2008 03:26 PM
2 best aluminum sprockets are Sprocket Specialist and Vortex...
jdzx14
posted December 15, 2008 03:39 PM
I have run nothing but Vortex on my bike, keep it lubed properly, and you can get just as many miles as the stock one.
2007 Black ZX-14
0.28280115127563 seconds processing time
