BIKELAND > FORUMS > ZX-14.com > Thread: putting on new chain NEW TOPIC NEW POLL POST REPLY
kawboy81
Busa Eater
posted December 10, 2008 06:33 PM
installed my extensions braided rear line and speedohealer...... popped old chain off with my motion pro chain tool and put on new chain....took a link out and pressed on master link.... started pressing/mushrooming pins in master link and when i got to last one, pow! one of the damn pins on the master link splintered at the hollow end right by tip.
i got 2 new master links on the way now, i know aot of you do this often chaging wheelbases etc, what is the EASIEST way to mushroom the heads on the pins of the new master link? do i have to use that tool? and how much am i looking to spread them out???
07 LE bolt on bike
rACeRs
posted December 10, 2008 07:12 PM
Id say get the tool. I just did mine for the first time and with a good chain tool its easy to do. I got the motion pro kit, which was less than $100 and well worth it. It comes with a special tip to mushroom the pins.
9.1 @ 149 w/ 1.57 60' SWB
kawboy81
Busa Eater
posted December 10, 2008 08:21 PM
i have the motion pro kit, i didnt have this much trouble spreading the pins on my other chain, i had to put a cheater bar on the t-handle just to get some leverage and it broke the tip of the pin (that u have to spread) on the masterlink.... how do u know when u have it spread/mushroomed enough????
07 LE bolt on bike
kawboy81
Busa Eater
posted December 10, 2008 09:13 PM
i take it not many of u dour own chains?
07 LE bolt on bike
Newbusa
posted December 10, 2008 10:34 PM
Never had that happen to me, Maybe it was a faulty link? Maybe you were not centered properly? I have had good luck with the motion pro tool,Good investment.
rACeRs
posted December 10, 2008 10:35 PM
If your using the riviter tip you can only conpress it a little bit less than 1/8th of an inch. And then the pin will be flush with the shelve part on the riviter tip. Its kind of hard to explain, but if your using the right tip it should be self explanitory. Your not using the same tip that you pushed the old chain apart with are you?
kawboy81
Busa Eater
posted December 10, 2008 10:40 PM
so the one i should be using is a tip instead of the long pin type thing? i have 2 tips and like 4 pins.... i was using the bigger of the long pins to spread it.
07 LE bolt on bike
rACeRs
posted December 11, 2008 09:54 AM
The biggest pin in the kit is the riveter, it is the only one with a little nipple on the end of it. Do you have that one? There should be 4 long pins one for a 520, 525, and 530 chain, and then the largest one with the nipple is the riveter. Hope that helps.
kawasakijockey
posted December 11, 2008 10:37 AM
Yes, some rivet links will shatter at the ends. It depends on the chain as some are extremely hard and should be flared somewhere between .010-.020 of an inch. Like I said, it depends on the chain. My EK chain did it on 2 links so I setttled for a .014 flare.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
kawboy81
Busa Eater
posted December 11, 2008 12:06 PM
well luckily i was using the right one (riveter)....i didnt have any instructions with mine and have never used it before exept to install chain on my stretched zx9 2 years ago.
kawajockey- yea it seems the chain i got is very hard. the D.I.D. for my zx9 and the stocker for my 14 was actually very easy to spread.... i have a ek zvx530 quadra ring gold chain..... came with extension package deal from schnitz. i notcied the chain felt beeffier compared to my d.i.d. and was a absolute b!tch to take a link out. i shattered the 530 pin trying to do so and had to fab a new pin out of an old titanium extractor....
07 LE bolt on bike
kawasakijockey
posted December 11, 2008 12:09 PM
same chain I have. measure it with calipers and then flare it out another .014 or greater.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
kawboy81
Busa Eater
posted December 11, 2008 12:26 PM
thanks man......maybe i was going for 2 much flare..... as soon as my new links come in ill give it another shot......thanks again.
07 LE bolt on bike
kawasakijockey
posted December 11, 2008 01:19 PM
Your welcome, no problem at all.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
0.23162317276001 seconds processing time
