BIKELAND > FORUMS > ZX-14.com > Thread: Replacing Oil Pan on 2007 FA model NEW TOPIC NEW POLL POST REPLY
Killjoy_1
posted December 01, 2008 05:05 PM
Any pointers on how to do this? I was looking at it and it did not seem like I had to disconnect anything major to get the job done. A friend of mine took a ramp too fast that had too much of an approach angle and ripped off the drain plug off of my ride.
smokinzx14
posted December 01, 2008 05:29 PM
Not much to do .... Pull the filter and drain the oil ... Remove the wire to the sending unit .. remove all the pan bolts and lower pan ... Make sure to take note where the orings are located .. You will have to swap the pressure valve and windage tray ( inside pan ) to the new pan ..
kawabunga
Cogswell Cogs Installed
posted December 01, 2008 05:36 PM
Bummer man. It's pretty straight forward. Just make sure you red loctite the bolts on the baffle plate and teflon tape your sending unit and install a new gasket. Careful on reinstall to locate your pickup & oil pipe correctly. Just pay close attention when you disassemble. Look for any shiney debris in the bottom of the pan and drain your oil in a clean pan and check it as well. I would advise a new filter at this time as well. Hope this helps.
kawasakijockey
posted December 01, 2008 05:52 PM
Does the new pan come with the oil filter nipple installed?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
smokinzx14
posted December 01, 2008 05:59 PM
I don't think it does , but it's easy the change...
johnsonzx14
posted December 01, 2008 07:42 PM
You will probably have to buy a new one... The nipple on mine was impossible to get out... Just order one and plan on changing it....
Red1
posted December 02, 2008 10:32 AM
Shannon at Clem's Kawasaki ( OSR Racing ) has modified pans for $150 ( exchange ) and $250 ( new pan ). The pans are cut and allow you to lower the bike 1.25 inches and relocates the drain plug to the rear. I have been using one on my 14 which is lowered front and rear 1.25" without any problems. I am completely satisfied with my pan and since I dragrace occassionally I needed the additional clearance. Let me know if you need Clem's phone number and I will look it up for you.
Thanks!
Red12/Blue14
KawaBonzai
Leader of the Back.
posted December 02, 2008 02:29 PM
This Clem's ???
http://www.clemskawasaki.com/
2009 ZX-14 Candy Lime Green
Red1
posted December 02, 2008 02:36 PM        Edited By: Red1 on 2 Dec 2008 22:37
That would be the one KawaBonzai!
Thanks for the assist!!
Red12/Blue14
Scalded Dawg
posted December 02, 2008 06:47 PM
I know that is doesnt...did the same thing on a deep pot hole...found out the hard way the nipple is not in the pan. You can buy one at an auto parts store and save some money. Kawi's is "ass rape" over priced. $9
$2 at NAPA
0.23469591140747 seconds processing time
