BIKELAND > FORUMS > ZX-14.com > Thread: New best today NEW TOPIC NEW POLL POST REPLY
rACeRs
posted November 22, 2008 09:21 PM        Edited By: rACeRs on 23 Nov 2008 05:24
New best today
I just got in from the track. Last time out my best was a 9.56 with brocks street map and 89 pump. Today I went on his track map, no air filter, and 89 pump since it was still in the tank from last time out. It was about 10 degrees warmer today then last time I ran, but besides that it was pretty similar conditions. It seems that I only picked up 1mph from the track map and no filter. Half way through the day I ran out of gas and went down to the gas station and filled up with 87 and headed back to the track, and It ran exactly the same on 89 and 87 so I guess I will run on 89 and not run the chance of detonating.
My best pass of the night was a 9.424 @ 148.217mph
here is how the slip breaks down
I1 1.583
I2 4.093
I3 6.136
mph 120.419
I4 0.000
et 9.424
mph 148.217
It was a slow test and tune day so I got to make 13 passes. 6 of them were 9,4x's and the rest were between 9.5x and 9.7x. I also pulled my best 60' ever on a bike a 1.533, I cant believe how well this bike gets off the line at stock length. I think it would be pretty cool if I could pull a 1.4x on it. And my best mph of the day was 149.x. I really wanted a 9.3x but couldnt pull one off to save my life.
Here are a few pics and a vid from the day.
9.1 @ 149 w/ 1.57 60' SWB
bawls
re-learning to ride
posted November 22, 2008 09:57 PM
Throw a catylist drag seat on it, and you may get your 1.4. Either way, you're putting out some bitching times. Keep up the good work.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
posted November 23, 2008 12:12 AM
you are doing awesome for a stock WB bike
pazx14rider
posted November 23, 2008 06:19 AM
Awsome man good times! im envious! we got snow on the ground here!!
rACeRs
posted November 23, 2008 09:23 AM
thanks, I need to look into one of those
smokinzx14
posted November 23, 2008 02:55 PM
Well done ....Nothing like beating a long bike with a stock wheel base bike !!!
Nelson Taylor
posted November 23, 2008 04:58 PM
Nice job racers.
Looks like you are having fun, and going fast.
The 9.3's are there once you get the bike in the 6.0's in the 1/8th mile.
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
rACeRs
posted November 23, 2008 05:44 PM
Yes i am having a lot of fun with this bike. I just need to get the throttle open sooner in first. I will try to keep going until I get those 6.0's and some 9.3x's
thanks for the replies
rACeRs
posted November 23, 2008 06:32 PM
Nice job racers.
If you dont mind me asking what gearing are you running. Im on stock gearing and thinking of trying out 1 down in the rear.
posted November 23, 2008 06:47 PM
imo go the other way(1 up on the rear or more) or your clutch wont like you. if wheelies are an issue try a lower launch rpm, and use the torque to do the work instead of a high rpm clutch slipping launch. just my .02
Nelson Taylor
posted November 24, 2008 11:08 AM
Stock gearing right now.
I've been told to go -1 in the rear to reduce the wheelie.
And also to go -1 in the front to get the bike out the gate quicker.
Not sure which way to go. I do need to try reducing the rpms and letting the torque get me going. I leave at 5000rpm and pretty much throw the clutch, and roll into the throttle.
Best #'s
1.54
4.03
6.02 @ 121mph
0.32108998298645 seconds processing time
