BIKELAND > FORUMS > ZX-14.com > Thread: ignition advance?? NEW TOPIC NEW POLL POST REPLY
kawboy81
Busa Eater
posted August 06, 2008 08:35 PM
ignition advance??
just curious, does the factory ecu advance or retard the ignition at all? I was looking into getting a adjustable ignition advance but if the factory ecu already has it's own ignition map then wouldn't it fight agianst it or say if I advance it 4 degrees and then the ecu advances 2 degrees under wot per say wouldn't that be 6 total? I'm on my cell can't type it out too well.
07 LE bolt on bike
posted August 06, 2008 11:03 PM
factory ecu advances for each gear, then retards the top of 6th near redline(speed limiter)
best results have been found with 4 degree's additional advance, and a speedohealer to fix up 6th.
lietoome
posted August 07, 2008 12:20 AM
+1
kawboy81
Busa Eater
posted August 07, 2008 12:24 AM
appreciate the input. Well I guess ima order me a advance and the healer. Thanks again.
07 LE bolt on bike
lietoome
posted August 07, 2008 12:35 AM
I plan on the ignition advancer @+ 4 degrees when I get home, already got the healer.
freddie900
zx 14 2007
posted August 07, 2008 04:15 AM
+1
madboost
posted August 07, 2008 05:09 AM
I run SB6 MSD ignition, it has ignition mapping and is adjustable up to +5/-20, i'm going down to HTP today to get a MR9 tune and i'll see if they want to mess with the ignition map to see if the bikes picks up any hp.
08 zx14-with a few things.
94z28 383,TH400,YSI,9",DFI and much more
9.44@144 w 1.5060ft
jdzx14
posted August 07, 2008 06:20 AM
How bad is it to install the advance rotor? And i already had mine dyno tuned so would i need to again, or how many degree's could i try? Sorry to thread jack.
2007 Black ZX-14
kawboy81
Busa Eater
posted August 07, 2008 03:20 PM
man it's real easy. 10 minute job. Just take off cover, remove old rotor. One nut holding it on my zx9r. I'm sure it's the same. Replace with new rotor. Reinstall cover. Just know ur own strength. Hahah I'm bad about overtightening bolts and aluminum isn't to fond of that sh!t.
07 LE bolt on bike
ninja14
posted August 07, 2008 05:03 PM
I modded my sensor and also have it locked in "N" vs. "6" - steady tuning
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
rapidroy
posted November 23, 2008 06:48 PM
Has anybody used the PC3 ignition module?
FastestBusaAround
I eat Fish...
posted November 23, 2008 08:55 PM
I bought a 4+ plate from Dubious and it runs well..pulls like a bat outta hell in the lower and mid ranges with no real issue.
FYYFF!!!
00Busa
Trying to go FASTER !
posted November 24, 2008 06:34 AM
Are there any downsides to advancing 3~4 degrees with the Muzzy plate. I have one but not installed right now.
'00 Busa / '06 14 /
IT AINT BRAGGING, IF YOU CAN BACK IT UP !
kimski2001
posted November 24, 2008 06:51 AM
Downside is timing is locked @ all times.I went thru three motors with that thing!Had mine set @ 6.5 degrees had it tuned twice on a dyno.Bike needed more fuel cause on each tear down pistons were melted on the skirts and the cylinder walls had piston material on them.They work really good with the proper fueling I believe.
1st14injax
00Busa
posted November 24, 2008 08:33 AM
I might better leave it alone - definitely don't want to have to do any tear-downs because of it.
'00 Busa / '06 14 /
0.2442479133606 seconds processing time
