BIKELAND > FORUMS > ZX-14.com > Thread: Big Bore zx14 NEW TOPIC NEW POLL POST REPLY
Y2KZX12R
CompetitionCNC.com
posted October 28, 2008 12:37 PM
Poll Question:
Big Bore zx14
How many of you guys would be interested in a reliable 88-90 mm bore in your zx14?
If so what would a block and piston kit be worth to you to be able to have really big reliable bores that would allow you to go deep into the 1600cc arena with a 66 mm stroke like the Busas?
This combo could potentially make make 260+ hp
Y2KZX12R
CompetitionCNC.com
Poll Results:
 9 votes (30%)
$2,000
 3 votes (10%)
$2,200
 4 votes (13%)
$2,400
 3 votes (10%)
$2,600
 4 votes (13%)
$2,800
 3 votes (10%)
$3,000
 4 votes (13%)
more
countersteer
Didn't read the owners manual
posted October 28, 2008 02:13 PM
would it be a kit like the muzzy 1375 with refundable core charge? id need more infomation before i decided on your question, but the 1375 was $2000 after core refunds and was well worth it.
Scott
Long Island, New York
2006 ZX-14, 2003 ZX-12R
countersteer
posted October 28, 2008 02:15 PM
and we would also need to find a welded or billet crank too right?
Scott
smokinzx14
posted October 28, 2008 07:30 PM
What about losing your vin numbers with the case swap ?
DogoZX
posted October 28, 2008 08:38 PM
Yea, I'd need more info.
When it comes time for me to do pistons, I plan on punching out the block as big as I can.
If you had a kit that includes a crank and pre-machined block, I'd definitely consider going that route.
Y2KZX12R
CompetitionCNC.com
posted October 29, 2008 04:25 AM        Edited By: Y2KZX12R on 29 Oct 2008 12:31
We dont have specific details yet, its still in development. We are several months away from a tested final product. Were hoping for Feb/March
You would send in your cases and get your cases back so the VIN would still be yours.
Cooling will be greatly improved and the deck will be MUCH stronger and have less distortion under high cylinder pressures like heavy shots of nitrous. You will need to use a special head gasket.
The bores will be offset. Looking from the outside on an assembled engine you wouldnt be able to tell anything was ever done to the cases. The cases will be double stress relieved and the mains line honed.
An offset ground crank isnt mandatory but wouldnt be a bad idea to re-center the rods under the pistons.
We could include the crank in the kit. But getting a crank made isnt really a problem these days.
We are working on a cylinder head to feed this beast as well.
How many we make of these "kits" depends on demand. Demand would dictate pricing.
So you can see why I'm posting this poll. we need to know what you would be WILLING to pay for this kit not what you would WANT to pay. We know you would want to pay $1500 but thats not reasonable, we just cant do it for that, theres a lot involved.
But if theres enough interest we can make this available to everyone at a reasonable cost.
Y2KZX12R
CompetitionCNC.com
posted October 29, 2008 04:35 AM
Sure sounds good Jim
Your always up to something!!!
Sticks_n_Stones
posted October 29, 2008 04:55 AM
The whole 14 world would be benefited by this kit, would hopefully put to rest a bunch of the drawbacks that keep serious drag racers and top speed'ers buying the Busa over the 14.
Wondering: that bore with streetable cams and compression (IE 92 octane pump gas and plug changes no less than every 5k miles) I assume would be good for 220 or so rwhp? Think it would last 20-30k miles? I'd be interested then.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
Y2KZX12R
CompetitionCNC.com
posted October 29, 2008 08:14 AM
Were still working on the setup... but lets say we can go to 89mm bore and a stock stroke of 61mm... that would be a 1516cc engine. Because its not a stroker, rod angle doesnt change. I'd expect to see 240-250 hp with a good head and cams.
Maybe 10 hp less with milder cams and less compression for the street. ???
But these are just estimates.... we will have to see.
Y2KZX12R
CompetitionCNC.com
kaw now
posted October 29, 2008 09:57 AM
Y2KZX12R not sure if this relates but what about Muzzy's pro stock set up. Would he not have a big block or is it not cooled as it is a drag only bike?
Y2KZX12R
CompetitionCNC.com
posted October 29, 2008 11:23 AM
I did talk to Rob a while back about the PS setup and its quite different than what we are trying to do. I really cant comment on it thou, I havent actually seen it.
I dont know if they are planning to make that available to the public.
Y2KZX12R
CompetitionCNC.com
S A Kruz
posted October 29, 2008 11:40 AM
Sounds sweet, you got me salivating already!
Kruz
2007 CBR 1000RR Red/Black Yoshimura RS-5 Full System, Flapper Mod and PCIII
2006 ZX-14 Passion Red, Flies Out, Yoshimura TRC, PCIII, TRE006a and Custom Map
2004 VTX 1300C Candy Apple Red
billeason
posted October 29, 2008 06:15 PM
I have a motor just waiting for this, lmk around about figure to do the crank and block and a head to flow this size motor. I'll send the motor to you when you need it, Its a spare so there's no rush on it unless i blow the other one up LOL... I think it would be better to have the whole combination done by one co. LMK Bill.....
bill eason
oldkawboy
posted October 29, 2008 07:02 PM
Hey Jim,
Would the stock 44mm throttle bodies be large enough for these combo's?
Thanks,
Dan
icarus
posted October 29, 2008 08:02 PM
I would also be interested in this as well. My primary concern would be longevity.
I would be racing on a weekly basis as well as riding approximately 5k miles
a year.
8.820 @ 161.05
Y2KZX12R
CompetitionCNC.com
posted October 30, 2008 06:20 AM
Were still working out the details and nothing is set in stone at this point. So I have no pricing yet.
Dan, the engine will want larger throttle bodies for these engines. We havent come up with a final combo, were working out the bore spacing,sizing, sealing,windowing,cooling, and head gasket issues now.
There is alot involved with this.
Y2KZX12R
CompetitionCNC.com
serius blk
posted October 30, 2008 08:45 AM
y2k i would be interested also. I still want to get my head done. But i guess ill wait to see what you come up with
killakaw4life
posted October 30, 2008 09:34 AM
Would be great right now as I have a bad motor. Price is the issue for me
Silver08
posted October 30, 2008 04:39 PM
I hope this becomes a reality. It could really shake things up for the 14 crowd. You can build a 240-250whp reliable 08 busa that you can ride all day long for $5-$6K. Y2k, if you could build a 14 that does the same for around the same money, you will be a very busy man.
in for updates
08 ZX14
gilberjj
Friend of Fast
posted October 30, 2008 05:49 PM
you can get turbo kits for 5-6k and they will put out 250whp or more. I would be interested if it was 2k or around there. I used my bike for the street mainly, but if you could make it reliable, then why not! I would love that kind of hp for the street!
Y2KZX12R
CompetitionCNC.com
posted October 31, 2008 04:09 AM
I here ya guys, Were trying to keep the cost down. At this point we are going to have to design a new wet liner. All the ones currently available wont work. Were trying to use a similar blank to keep cost down. If we have to have new blanks spuncast then the price will be a few hundred bucks higher.
We are trying to keep it under $3000 complete.
Y2KZX12R
CompetitionCNC.com
posted October 31, 2008 04:52 AM
gilberjj...The tubo's on a 14 are much better than a 12 but still not up to par with a Busa...
For the 14 all motor is the best option...
serius blk
posted October 31, 2008 05:23 AM
under 3000 would be good. Im sure you would need to get the head done also. I wonder what kind of performance would you get with the stock setup. Just adjusting the cams.
Y2KZX12R
CompetitionCNC.com
posted October 31, 2008 12:54 PM
Yea, cams and a ported cylinder head will be the only way to really get the max from this combo.
Y2KZX12R
CompetitionCNC.com
Y2KZX12R
CompetitionCNC.com
posted November 05, 2008 03:40 AM
Some news, Its looking like the bottom of the block boss is only going to allow an 87mm bore with slightly offset wet liners. Theres just not enough material to support the offset wet liner if moved out any more, and I dont think there would be enough demand for a dry block.
Keep in mind that the deck sealing surface will be ductile iron and will seal better than the stock, bored out, aluminum deck. These liners will take a turbo or heavy nos.
With a stock crank the 87mm bore would be 1450cc and with a 66mm crank it would be 1569cc.
Y2KZX12R
CompetitionCNC.com
0.2576150894165 seconds processing time
