BIKELAND > FORUMS > ZX-14.com > Thread: traction NEW TOPIC NEW POLL POST REPLY
zerotahero
posted October 26, 2008 07:26 PM
traction
today i went for a ride and my bike must be starting to loosen up a bit. i have an 6 inch swingarm on it and before i would start out from a dead stop and i was able to take off without any trouble. now soon as i hit about 70 or 80 my back tire breaks loose and i fishtail
for a second or two but today it did it and i got a little pissed so i grabbed second gear and it did it again in second gear this time i was probley doing about 90 or so. i have the muzzy four into one with the mega phone and the pclll with the flies in still and racetech springs
plus metzler m1 series tires. CRAZY HELP i would really like this thing to hook up so i could enjoy the power. thanks
NOX
PMRA / TMRC Super Street 4022
posted October 26, 2008 07:56 PM
Shock set up wrong, and lots of air pressure in the tire......., on the street.........
We deal with it on prepped tracks if they do not spray the top end well............
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
zerotahero
posted October 26, 2008 08:49 PM
not enough air in the tire too much how many psi should i run? my shock too stiff or not soft enough i think it is on the highest setting meaning it is on the stiffest setting because i weigh about 240? thanks bro
posted October 27, 2008 02:14 PM
put the stock swingarm back on and you will have more hook than you can use
posted October 27, 2008 04:17 PM
How much colder is the temp now compared to when you didnt spin???
Did you have the swingarm back then when you didnt spin???
zerotahero
posted October 27, 2008 09:11 PM
no it has been on the bike from the day i bought it.
posted October 28, 2008 05:16 AM
Either your getting more aggresive with your throttle or the tire is getting old as in too many heat cycles...
Plus, what everyone else said...
But you still didnt give us enough INFO.....How many miles, what tire pressure and how old is it???...Did you touch the rear shock settings???...Change the gearing???...Whats the temp over there now???
zerotahero
posted October 28, 2008 02:29 PM
5250 miles on bike,temp was about 65 that day, 1000 miles on new tires metzler m1 series
tire pressure is at 42 psi while cold before being ridden, and i have not touched the rear shock settings. i know the dealership set it up that way, anyway it did not do it near as bad before. i am also not a real aggressive rider, so i don't go through alot of tires very fast they tend to last me a while. tires before these ones were stock they found a scew in my front tire so i had them replace both of them, also running a 200 instead of a 190 cause thats all they had. thanks guys.
posted October 28, 2008 02:38 PM
Was it a cloudy day???
It has to be due to the cooler weather and cold streets!!!
Put 36lbs in it...
zerotahero
posted October 28, 2008 06:48 PM
thanks i will try that and see if it works.
smokinzx14
posted October 28, 2008 07:10 PM        Edited By: smokinzx14 on 29 Oct 2008 03:11
Good luck , i have never seen a zx14 at 6 over that would hook on the street and i don't care what tire you have ...6 over is about 63 1/2 inches long and that is not going to work on the street .. My Shinko at 17 psi will blow the tire off at speeds over 130 MPH on some streets .... If you can get on some good concret you may have a chance of hooking ..
BADBOYINDC
2007 ZX14 Black
posted October 29, 2008 05:55 AM
THE BEST I CAN TELL YOU IS TO TAKE IT DOWN TO 36PSI AND THAT SHOULD CLEAR IT
UP FOR YOU
I HAVE A 8 OVER ARM ON MY BIKE AND I HAVE THE SAME PROBLEM YOU HAVE A BUCH OF POWER WITH THE 14 NOW LET LET IT STAY ON THE GROUND
Brock exhust 16/45 sprockets,
Nos, Mactosh arm 8inches over
Powercammander ajustable lowering links airshifter all the good shit Crome Rc wheels
LET IT DO WHAT IT GOING TO DO
serius blk
posted October 30, 2008 08:55 AM
i have the same setup but im 8 over. I set my susp alittle soft with coil. Its hard to get it dialed in because that coil is so stiff. With 35psi in the tire i can launch it. Ive beat alot of people on the street doing this because i take off at 2500 rpm. Anything higher will break the tire lose. It seems to work. Ive tried other things like heating the tire up alot. That does nothing but make it spin worse. With the u soft it works best when it slightly heated like from a high speed run or something. To hot and get no traction. At the track its a total different situation. Also like smokin said concrete will also work.
zerotahero
posted November 01, 2008 07:05 PM
what is the u soft. dont know what you are talking about. let me know thanks.
01smokes
posted November 01, 2008 09:01 PM
its a tire, its called a shinko 003 ultra soft compound
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
bawls
re-learning to ride
posted November 01, 2008 10:00 PM
I run 29psi rear, and 31 front... one of our pilots is a semi pro road racer, and told me to try that out. I hook a lot better, and the handling is better as well.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
fastest-14
Fastest -14
posted November 02, 2008 11:43 AM
42 PSI? You have waaaaay to much air in the tire. That's your biggest problem. I would definitely go 30 psi for roll ons and as low as 20psi for dead stop launches but 42psi, that's usually the max on some tires but you won't get great traction from that high of a psi.
gilberjj
Friend of Fast
posted November 02, 2008 03:24 PM
sit on the passenger seat. You'll get traction that way.
Burnrubber1
Some chrome
posted November 02, 2008 09:08 PM
My bike is an '07 with stock Bridgestone Battleaxes and they suck! After putting a dual shorty exhaust on it, I can't get it to wheelie much with all the wheelspin I get now. I had a ZX10R with Dunlop Qualifier tires on it and those tires got sticky really fast no matter how many times I burned 'em off at the track and I ran those with the recommended air pressure. Just my two cents!
serius blk
posted November 03, 2008 04:49 AM
i have a friend thats been racing with that stock battlax and its been sticking to the street and track. He lowered the psi to 20psi
gilberjj
Friend of Fast
posted November 03, 2008 09:26 PM
i only spun the battlax once or twice. i like my avons better though
0.36047601699829 seconds processing time
