BIKELAND > FORUMS > ZX-14.com > Thread: Removing front wheel NEW TOPIC NEW POLL POST REPLY
NeverKnow
posted October 29, 2008 08:07 PM        Edited By: NeverKnow on 30 Oct 2008 04:48
working on images
Alternative part to expensive socket to remover front wheel
NeverKnow
posted October 29, 2008 08:47 PM
Inside hex removal from right side facing the bike
22.92mm inside hex measurement
Alternative part to using socket
Cost difference
Grind on wheel or with Dremel (TM) tool
Standard 7/8 socket fits fitting
Torque to 93.7 foot lbs
DogoZX
posted October 29, 2008 11:13 PM        Edited By: DogoZX on 30 Oct 2008 07:37
Nicer than my ultra low budget alternatives:
A) Find a nut and bolt combo (preferably from a coffee can or Mason jar) and weld the nut to the bolt with the sh*ttiest welds you can manage.
-or-
B) Dig out a sparkplug wrench (preferably split, flared, and stripped from breaking lugnuts loose w/ an impact) and stick an extension in it backwards.
Total cost: Freeninetynine
Thanks for the writeup. I think I might upgrade!
NinjaNick
'08 ZX14 (Blue)
posted October 30, 2008 09:49 AM        Edited By: NinjaNick on 30 Oct 2008 17:52
Sounds like you have some good tools to be worrying about a $30 socket. I got a universal socket with many sizes to fit many different bikes for less than $30. I can put it in a front axel of any motorcycle and it'll work. It makes me happy.
KawaBonzai
Leader of the Back.
posted October 30, 2008 10:21 AM
There is a tool included in the 09's toolpack that does this. I'm gonna go look in my 08 toolpack since I kept it from the slavage yard, lol.
2009 ZX-14 Candy Lime Green
Scalded Dawg
posted October 30, 2008 01:08 PM        Edited By: Scalded Dawg on 30 Oct 2008 21:09
And thanks for the link/name/place of purchase of said miracle tool...And I wish it made me happy.
S A Kruz
posted October 31, 2008 07:57 AM        Edited By: S A Kruz on 31 Oct 2008 16:20
Craftsmen 1/2" drive 13/16" deep sparkplug socket and 6" long 1/2" drive extension installed backwards. It is a perfect fit into the axle nut. Total cost of both items from Sears about $11. Took about 10 minutes to run over there and pick em up with zero aggravation. Loosen the axle pinch bolts only on the throttle side. Clutch side pinch bolts stay tight and keep the axle from turning. One more thing, make sure you have a good front stand with no flex. I saw one guy use a cheap set of stands and they allowed the forks to move together a little after the front wheel was removed. It is a bitch getting the front wheel back in when that happens. You will have to drop both brake calipers and either remove the front fender completely or take the bolts out on one side in order to get the tire out. If you have the ZX-10 fender the tire will clear without removing the fender. Torque is 94 lb-ft on the axle nut and if I remember corrrectly the pinch bolts are 12lb-ft. Have fun!
Kruz
2007 CBR 1000RR Red/Black Yoshimura RS-5 Full System, Flapper Mod and PCIII
2006 ZX-14 Passion Red, Flies Out, Yoshimura TRC, PCIII, TRE006a and Custom Map
2004 VTX 1300C Candy Apple Red
bulldogprostock
posted October 31, 2008 09:37 AM
I changed my tires a week before a trackday and was shocked when my kit (2008) didn't include a tool for the front. There is no excuses for Kawasucky not to include something that basic in the stock tool kit !!! I'm lucky and have a well stocked tool supply and used the same trick as S A Kruz
2001 Busa, 2008 ZX14R, K6 GSX1000R
NinjaNick
'08 ZX14 (Blue)
posted October 31, 2008 12:36 PM
LOL, sorry, mine was giving to me at a trackday, so it was free for me.
I've seen it once online before. I will look it up tonight and post it for you. Give me a few hours and I'll get a link for you. Sit tight. I'll brb.
Nixter
posted November 02, 2008 08:01 PM        Edited By: Nixter on 3 Nov 2008 04:02
I use one of these http://www.kneedraggers.com/details/Motion_Pro_Hex_Axle_tool--614662.html
It has multlple sizes so can be used on all kinds of bikes.
2012 ZX14R - Black
Bluebyyou
Gettin My Curve On
posted November 04, 2008 03:35 AM        Edited By: Bluebyyou on 4 Nov 2008 11:36
Cycle Gear, MOTRAX axle wrench, multiple bike application (3 sizes) only $16.99. works great.
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
NinjaNick
'08 ZX14 (Blue)
posted November 04, 2008 06:41 AM
Yep, mines a motion pro.
posted November 04, 2008 06:44 AM
Whole crowd of McGyvers around here when it comes to making a front wheel tool huh :P
WindSwordNinja
posted November 04, 2008 06:50 AM
R.D.A. rocks!
He was great in Stargate SG1 also.
2014 ZX14 Black and Green
2008 ZX14 Black and Red SE
1986 ZX1000R Black
"Faster, faster! Faster would be better!" (Serenity)
posted November 04, 2008 06:58 AM
R.D.A. rocks!
+1
0.33512902259827 seconds processing time
