BIKELAND > FORUMS > ZX-14.com > Thread: Swingarm Nitrous Mount/Pics? NEW TOPIC NEW POLL POST REPLY
posted October 30, 2008 02:18 PM
For those of you who have mounted their nitrous bottle in front of the rear wheel, could you provide some pics? I am trying to get an idea of the clearance, and the best way to get the bottle in and out with various setups.
Thanks.
smokinzx14
posted October 30, 2008 03:59 PM
01smokes
posted October 30, 2008 06:37 PM
is that a stock arm smokin? and how far out does the bike have to be to clear 2.5lb bottle?
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
smokinzx14
posted October 30, 2008 07:14 PM
Yes it's a stock arm ... You need to be about 62 inch wheel base to be safe ..
posted October 31, 2008 10:20 AM
Lee, how do you get the bottle out? Is there clearance above it or do you need to put it up on a stand, or??
smokinzx14
posted October 31, 2008 11:57 AM
The bottle comes right out if you mount it with the valve facing up ...With the valve facing down you have to raise the bike up ..... Valve up is fine just make sure the bottle has a tube installed...
burnout
posted October 31, 2008 12:05 PM
You can always make the bottom bracket removable to help with clearance and pulling the bottle through two rubber caked brackets. Mine uses a wing nut to attach. Two brackets might be overkill, but AMA Dragbike requires it in certain classes.
1/8 5.66@129.77
1/4 8.74@159.60
posted October 31, 2008 12:08 PM
Great pictures, thanks!!
billeason
posted October 31, 2008 04:56 PM        Edited By: billeason on 1 Nov 2008 00:57
brackets
Man somebody is a damn good welder Very nice..... Bill
bill eason
pazx14rider
posted November 01, 2008 06:10 AM
Hey smokin lookin to use the duel bottle under tail that dubious was running...is that position safe for a air shifter bottle?
1badvespa1400cc
power junkie
posted November 01, 2008 06:17 AM
Is that a aftermarket fuel pump I see???
Just another foeteen!!!!!
smokinzx14
posted November 01, 2008 06:30 PM
Yes it will be just fine ...
pazx14rider
posted November 02, 2008 05:50 AM
Thanx smokin and enjoy that new ride!
posted November 02, 2008 06:13 AM
You can mount the cylinder in that spot, but you need to be careful of how far the valve and regulator protrude. Make sure that the valve won't snap off if the bike falls over. That could be very dangerous.
I only mention it because I had to relocate my bottle in order to pass tech at Maxton.
pazx14rider
posted November 03, 2008 01:29 PM
Ok ill keep that in mind thanx shane
0.32532405853271 seconds processing time
