BIKELAND > FORUMS > ZX-14.com > Thread: how much fuel to add 30 shot NEW TOPIC NEW POLL POST REPLY
06redzx14
posted October 10, 2008 06:40 AM
How much fuel should be added for a 30 shot dry?
smokinzx14
posted October 10, 2008 06:53 AM
I added 12% on the high side of the P/C on my zx14 for a 30 shot ...It worked well and never had a problem ... I did use 93 while using the spray ..
06redzx14
posted October 10, 2008 06:55 AM
do you know what range that would be in if you went through the software?
smokinzx14
posted October 10, 2008 07:02 AM
12% is 12% no matter how you add it ... I would say add 12% at 80% and 100% throttle from 6000 RPM up .. Don't trigger the spray till you are at wide open throttle .. I had my spray come on by a micro switch on the throttle bodys ... It was set to come on at full throttle ..
06redzx14
posted October 10, 2008 07:05 AM
OK thanks smokin that's what I was trying to figure out whether to do it at just 100% or 100 and 80
kawasakijockey
Smokin, was it hot weather when you had that nitrous setup? Reason I am asking is bottle pressure will play a factor with the air temp.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
flyboy
posted October 10, 2008 09:38 AM
Smokin--
What if any would the dangers being using the NOS at 50-60% power?
Bill
"The World's Fastest Indian"
One fast red ZX-14,
smokinzx14
posted October 10, 2008 11:22 AM
When i ran mine in the heat i had a problem with the bottle pressure getting way to high ... so high it would lock up and not come on ... I would have to bleed the bottle pressure down to 950 to get it to work .. As long as i kept it around 900 psi all was fine ...
smokinzx14
posted October 10, 2008 11:31 AM
Smokin--
Bill
I have to ask why you would want to use it at 50% or 60 % throttle ? If you are racing you would only see those numbers for a split second in first gear .. If you wanted to turn it on at 50% throttle i would map it for those numbers so not to have any damage..
If you have it coming on at 100% throttle i like to have the fuel allready on at 80% just to be on the safe side , it also softens the hit to have the fuel come on before the spray ..
0.28008198738098 seconds processing time
