BIKELAND > FORUMS > ZX-14.com > Thread: Crank breather mod NEW TOPIC NEW POLL POST REPLY
1badvespa1400cc
power junkie
posted October 09, 2008 11:03 AM
Crank breather mod
Any pics would be nice,doing mine this weekend,I know how it basically needs to go but other ideas would be cool too.
Just another foeteen!!!!!
davisag
posted October 09, 2008 01:16 PM
my couple of pics
turned the right angle bend round 180 degrees to allow breather to exit rhs as more room on this side
1badvespa1400cc
power junkie
posted October 09, 2008 02:35 PM
Is that on a zx14?
dcjens
Wet side of Washington
posted October 09, 2008 04:57 PM
what exactly are we doing here? crankcase breather connected to? reed valve air suction at the valve cover? what does this do? stop/reduce the backfire? I tried plugging the line from the airbox to the reed valve. I didnt help much I took it back out. need info here. Correct me if Im wrong... does the ignition spark twice ...once on compression stroke and once when the exhaust valve is open? My old KZ did this. Nothing happened as their was no fuel or compression. On the 14 does this extra spark have unburned gasses that fire? hence the backfire? I'll stop here and take another drink of my bathwater...mmm....sudsy
Black 06
1badvespa1400cc
power junkie
posted October 10, 2008 05:01 AM
dAVISAG WHERE IS THE BREATHER AND DO YOU HAVE ANY PICS WHERE YOU PLUGGED OFF THE FRAME ANY MORE HELP WOULD BE NICE,THANKS!!
davisag
posted October 10, 2008 08:12 AM
hi
the breather is connected by the shown pipe direct from the engine crank breather plate, to the reed valves on rocker cover with a t piece fitted.
frame is plugged where the original crank breather pipe joins the frame
art
posted October 10, 2008 08:16 AM
I wonder how many people here are successully using this mod?
I thought there was some concern on the 12R with it affecting oil pressure at idle? Maybe it was Entropy who saw that?
SteddyTeddy
posted October 10, 2008 09:26 AM
I did that on my ZRX a while back. No gains on the dyno but also didn't hurt anything.
1badvespa1400cc
power junkie
posted October 10, 2008 12:46 PM
If anyone has anymore pics that would be sweet.
0.26717114448547 seconds processing time
