BIKELAND > FORUMS > ZX-14.com > Thread: 07 ZX-14 Sprocket Change NEW TOPIC NEW POLL POST REPLY
epd345
posted October 06, 2008 12:50 PM
I see alot in the forum about people changing the front sprocket? I know it gears up or gears up the bike but what is the common upgrade for the ZX-14? Do you need a speedo healer if you change the front sprocket? Thanks
BobC
posted October 06, 2008 01:18 PM        Edited By: BobC on 6 Oct 2008 21:19
Sprinters often go down to a 16 tooth and top speed junkies like me have been known to go up to 18 tooth.
You will need a Speedo Healer if you are concerned about speedo accuracy or if you want to defeat the top speed limiter (by setting it to under-read).
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
epd345
posted October 06, 2008 02:09 PM
Whats stock?
madboost
posted October 06, 2008 02:16 PM
17
08 zx14-with a few things.
94z28 383,TH400,YSI,9",DFI and much more
9.44@144 w 1.5060ft
epd345
posted October 06, 2008 02:54 PM
Gonna get a 16 I think
smokehouse4444
XX to ZX
posted October 06, 2008 04:23 PM
You'll notice a big difference with the 16t...much stronger acceleration.
2008 Atomic Silver ZX-14, Brock's this and that, some other stuff, 260 in full gear, powered by Cheese
2005 Ducati 999 with all the goodies
gilberjj
Friend of Fast
posted October 06, 2008 07:37 PM
I think I will be ordering a 16 tooth as well....... now I hope it stops raining long enough for me to try out the bike with the change.......
madboost
posted October 07, 2008 04:41 AM
if you heavy 250lbs+ 16T is good choice, i tried them all i'm about 170lbs and 16t front was useless in 1st, or should i say 1st gear was useless. I'm now extended and went 3 up on the back with stock front wich is essentially the same, the longer wheelbase is helping some but i think the gear is still too short and bike wants to lift alot, so i'm going back to stock gearing.
9.44@144 w 1.5060ft
Hurricane
posted October 07, 2008 07:46 AM
Make sure you get the factory 16 tooth with the rubberized coating. Otherwise it sounds like a semi truck.
epd345
posted October 07, 2008 09:38 AM
Yea Im 325lbs so I will order a factory 16t. What will that do to my speedo reading? Thanks for all the help
gilberjj
Friend of Fast
posted October 07, 2008 10:32 AM
The best thing you can do is pull those flies, especially with your size!!!!! You won't regret it.
epd345
posted October 07, 2008 02:16 PM
Will pulling those flies void my warranty, my bikes about 4 months old and I bought the 3 extra years of warranty from Kawi.
KawaBonzai
Leader of the Back.
posted March 05, 2009 07:41 AM
Ok, I'm sold on getting a 16t for the front.
should I go OEM for the vibration free rubber coated thingy, or go with a Schnitz or Vortex sprocket?
Also, what is the part number for the rubberized 16t front? It's not off the 14 is it?
2009 ZX-14 Candy Lime Green
cajunboyz
posted March 05, 2009 08:09 AM
I believe the Part # is 13144-1317 ,from the old Zephyr 1100...
NinjaNick
'08 ZX14 (Blue)
posted March 05, 2009 02:52 PM
I went vortex front and rear.
0.22643494606018 seconds processing time
