BIKELAND > FORUMS > ZX-14.com > Thread: high flow air filter vs stock filter NEW TOPIC NEW POLL POST REPLY
GripnRIp
posted September 21, 2008 04:16 PM        Edited By: GripnRIp on 22 Sep 2008 01:09
i've heard from more than one person that you should not use a high flow filter because of the ram air feature. the small gain (1hp) from using the high flow filter is not worth the increased dirt/bugs getting through. are there any experts here that can make a recomendation?
also Muzzy does not make a map for anything other then stock air filter. i though that might be a good indicator to stick with stock.
3Boysand3Bikes
posted September 21, 2008 09:00 PM
There has been quite a bit of information talked about on the Forum... To save you a bit of trouble looking it up... I believe that there is only a minor change with air filter change. Look back and read a lot of the information that has already been talked about. Check out secondary "flies" removal also. Depending on the year bike you have, that is the best bang for your 'buck'. If you have already done so... just ignore me. If not, look it up on here. There is a TON of information.
The stock air filter breathes extremely well and it is not like the 80's where it is a 'must have'. I hope that helps. Welcome to the Forum...
lietoome
posted September 21, 2008 11:25 PM
Regardless of gains, I like the BMC street filter. I would much rather clean & reuse the BMC instead of purchase a stocker at the local dealership.
bawls
re-learning to ride
posted September 22, 2008 04:55 AM
If you are going to search, use the one in the top left. The search bar on the right is worthless
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
GripnRIp
posted September 22, 2008 03:05 PM
the one on the left has been just as worthless for me. it pulls up everything regardless of my request.
Bently
2012 14r In Blue and no Mods!
posted September 22, 2008 06:28 PM
i still agree the search on this site sucks
bawls
re-learning to ride
posted September 22, 2008 06:39 PM
I agree 100%. I'm a firm believer in taking 30 seconds to answer a question lol.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Bently
posted September 22, 2008 06:48 PM
+1
posted September 22, 2008 06:55 PM
BS... works fine... type your search in the white "search" box and search away.
0.24327898025513 seconds processing time
