BIKELAND > FORUMS > ZX-14.com > Thread: melted boot on brocks pipe/ NEW TOPIC NEW POLL POST REPLY
pazx14rider
posted August 18, 2008 03:29 PM
anyone have any advice on what to use to get burned rubber from my boot off my brocks short meg, tried mineral spirits, tar and bug remover, windex, and suzuki motorcycle wash. i know steel wool will take it off but i dont want to scratch the pipe help! it looks like hell!
KawaBonzai
Leader of the Back.
posted August 18, 2008 03:35 PM
This may sound strange, but I had that happen on a Harley once.
I burnt the rubber off with a lil propance torch. Did not discolor pipe.
I'd suggest riding until it get soft/pliable then use a shop rag soaked in water and wipe off. You may need to reheat and do a couple times to get the majority of the rubber off.
After that when the shadow is all thats left, the mineral spirits or any citrus cleaner should finish it off.
G'luck.
2009 ZX-14 Candy Lime Green
countersteer
Didn't read the owners manual
posted August 18, 2008 03:53 PM
i believe brock sells a chemical solution on his website specifically for this.
Scott
Long Island, New York
2006 ZX-14, 2003 ZX-12R
street racer
posted August 18, 2008 03:54 PM
Lacquer thinner and steel wool will take it right off. Dont ask how I know this !!!
headvince
posted August 18, 2008 04:16 PM
I have never tried this but i heard someone used easyoff oven cleaner to get off burned plastic.
warbird
posted August 18, 2008 04:32 PM
Easyoff oven cleaner! Spray it on a rag THEN apply it to the pipe. Don't spray that stuff anywhere near your bike. Soak that spot good then wait about 20 minutes. It may take more than one try but it will come off..................
I'd Rather Be Roadracing.
pazx14rider
posted August 18, 2008 05:21 PM
ok im goin to take your guys word on the oven cleaner let u know how it turns out! thanx
xtro
posted August 18, 2008 05:47 PM
steel wool on stainless steel ??? uh ... not sure I buy that part ...
I tried that on an older bike and sold it with the scratches intact years later ...
ust a thought ..
kawracer
posted August 19, 2008 04:04 AM
WD-40
2004 & 2005 PMRA Street E.T. Champion
bawls
re-learning to ride
posted August 19, 2008 04:48 AM
human feces
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
dbeadling
posted August 19, 2008 05:12 AM
the t rue meaning of a hot pipe
Sticks_n_Stones
posted August 19, 2008 06:02 AM
WD-40
Yep, thats what I've always used. Works like a charm! I found out about it when I was spraying my shock actuator to get rid of a squeek on my TLR and oversprayed a built up shoe rubber mark on the pipe. When I went to wipe it off, the old crusty multiple layers of black came right off. Man after that I used WD40 for everything: chain, rims, swingarm, exhaust, .... if it squeeked, rusted, was dirty, or was bare metal it gets wiped with it!
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
kawabunga
Cogswell Cogs Installed
posted August 20, 2008 02:14 AM
Use 0000 steel wool. You can buy it at Lowes, Home Depot. 0000 steel wool will not scratch glass or chrome. Dip it in some laquer thinner and go to work. You will like the results. Afterwards take some semischrome polish to a mirror finish.
lietoome
posted August 30, 2008 02:34 AM
Not sure if this could help in the future...
http://www.targa-acc.com/cgi-bin/products.cgi?name=upc_code&value=18-500BK&format=3
ratbyk
posted August 30, 2008 08:15 AM
WD-40 works great removing old adhesive from duct/masking tape etc. Works just as well as contact cement cleaner. Won't scratch
Just let it soak the area a bit to soften the area then rub off.
obba
posted August 30, 2008 03:31 PM
WD40 removes chewing gum off leather sofa's, chairs etc.
Much better than the frezzo stuff, which can take the top of the leather with it.
Even Wrigleys support people didn't know that, cause i rang them desperate to get the chewing gum off our expensive leather lounge.
posted August 30, 2008 04:03 PM        Edited By: dubious on 30 Aug 2008 17:04
WD-40
+1
for years I have used it on everything metal but the rotors...
also....keep it off the seat, grips, and tires too...
pazx14rider
posted August 31, 2008 09:47 AM
Just an update on the tread if anyone was wondering used easy off oven cleaner had to let it soak on the pipe, but alot of scrubbing it came off thanx everyone
0.26586818695068 seconds processing time
