BIKELAND > FORUMS > ZX-14.com > Thread: Header Tightning Sequence NEW TOPIC NEW POLL POST REPLY
StrokedOutZX14
Saving for a turbo by tax time
posted July 23, 2008 09:26 AM        Edited By: StrokedOutZX14 on 23 Jul 2008 10:48
Should I start in the middle and get them snug working outwards, then go back to the middle and give them a final torque working outward again or does it not matter?
07 ZX14 Stroked to 1530cc
Muzzy 5mm Stroker Crank, 86mm JE Pistons, Carillo Connecting Rods, Muzzy Billet Cams, Muzzy Valve Springs, Rings, Pins, Clips.
Muzzy M10 Exhaust
K&N Air Filter
Power Commander 3 With Ignition Module.
Secondaries Removed
  Ignore this member    Click here to visit StrokedOutZX14's homepage.
kimski2001
posted July 23, 2008 10:29 AM
good question cause i cant seem to get rid of a small header leak on my smeg.
1st14injax
StrokedOutZX14
posted July 23, 2008 01:04 PM
number 2 been leaking on me. replaced gaskets today, see if the helps.
Muzzy M10 Exhaust
K&N Air Filter
Secondaries Removed
posted July 23, 2008 01:17 PM
wow, exhaust leaks where the exhaust meets the head???
shane661
posted July 23, 2008 01:22 PM
Yes, up at the head. I had the same problem, so I installed new gaskets. You can see the difference here:
posted July 23, 2008 04:45 PM
wow, thanks for the pic. I reused my gaskets in the 14 and never had a leak in that area. had I seen these beforehand, I'd have used fresh ones
smokinzx14
posted July 23, 2008 08:50 PM
+1 i have reused mine so many times i lost count ... I do mine on no order at all ... but i do pull them up even, a little bit at a time ...
Zedexdragon
posted July 24, 2008 05:53 AM        Edited By: Zedexdragon on 24 Jul 2008 06:54
If you have the time, drop the radiator out of the way. Its three bolts and loosening the fan cable. Radiator drops down and forward giving you enough room to get in there. Takes about 20 minutes start to finish. This is what I did when I installed my SMEG and had a leak on #3.
Also slip some cardboard on the back of the radiator to protect if from wrench slipping.
Cheers
Kinley
0.29443502426147 seconds processing time
