BIKELAND > FORUMS > ZX-14.com > Thread: quarter mile times NEW TOPIC NEW POLL POST REPLY
pazx14rider
posted July 21, 2008 05:09 PM
quarter mile times
Ok guys took my 14 to the track friday first time, first the bike...07 zx14, brocks short smeg, pc3 street map, flies out, with baffle in everything else stock.
R/T .005
60' 1.809
330 4.513
1/8- 6.663
mph 11516
1000 8.507
1/4 10.07
mph 143.75
The bike is not extended or strapped deffinitely have difficulty at the line cant use all the power it will wheelie hard if i do. Any luck launching a stock bike rpm? would be helpful i believe im comming off at 6000 rpm. Thanx
kawasaki_rick
posted July 21, 2008 05:24 PM
Keep practicing Itl get better, thats not bad 1st time out. Put extensions on and itl go way faster.
Wheelie
Old Man
posted July 21, 2008 05:30 PM        Edited By: Wheelie on 21 Jul 2008 18:30
first time at the track and stock suspension? thats not a bad time!
wee
pazx14rider
posted July 21, 2008 06:18 PM
forgot to metion 90 degrees with high humidity!
smokehouse4444
XX to ZX
posted July 21, 2008 07:32 PM
Damn, I think I would be WAY happy with that paz! I will probably go for the first time this coming Friday. Going to be different than beating GIXXERS and R1's at late night lights with my old XX. I hear I am going to SUUCK real bad first time out. I've been very technical practicing. Find an empty parking lot, count out 20 paces, launch and think one one thousand, two one thousand and beat that. Quite Neanderthal if I do say so myself. So congrats on the good night, and keep two wheels down.
2008 Atomic Silver ZX-14, Brock's this and that, some other stuff, 260 in full gear, powered by Cheese
2005 Ducati 999 with all the goodies
madboost
posted July 22, 2008 03:10 PM
thats good my first time out with mine was 9.96@146mph w a 1.78 60ft.
Tiforce high mount full system/bazzaz/lowered and straped, 89% humidity and 97 degree heat. Youre doing very well though i would def strap that bike and lower it, you doing very well for your first time.
08 zx14-with a few things.
94z28 383,TH400,YSI,9",DFI and much more
9.44@144 w 1.5060ft
pazx14rider
posted July 22, 2008 04:51 PM
thanx anyone have suggestions on what rpm to try shifting at?
bawls
re-learning to ride
posted July 22, 2008 05:14 PM
11,200 lol
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
smokehouse4444
XX to ZX
posted July 22, 2008 05:46 PM
I just posted this on drag bike. On my XX, after the initial launch I didn't have much problem with this, but my new ZX-14 is a different animal. I saw where Rickey Gadson said if the front wheel is coming up, its your bikes way of telling you to shift. So if I'm in first gear at 8000 and the wheel is coming up, he's not saying to go ahead and shift there is he?
pazx14rider
posted July 23, 2008 05:34 PM
thanx for the input from eveyone, and smokehouse i dont think shifiting at 8000 would be right either i need to go look at brocks dyno runs and find out when peak hp is then shift around that point
posted July 23, 2008 07:14 PM
i agree, thats wayyy to early to shift, just try letting out as minimum as you can still allowing the front wheel to stay as close to the ground as possible. i ran 9.7's with it just lowered and strapped. mph is usually around 143 to 144
smokehouse4444
XX to ZX
posted July 24, 2008 05:00 AM
To follow up, some of the guys on Dragbike did say that is what Rickey was saying to do. If the wheel was coming up hard on you, then go ahead and shift and hopefully the taller gearing would bring the wheel down. The time would not be as good, but would be better than letting off on the gas. But they made a point of saying to just keep enough power to allow that front wheel a little off the ground, but with as much juice as possible...peg it when you can. Like I've seen on here many times...practice, practice, practice. Thanks for the help!
BobC
posted July 24, 2008 05:35 AM
Great time for a stock bike.Strap the front and you'll be in the Nines.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
0.55174589157104 seconds processing time
